Vistitle acting odd on opening
  • Vistitle acting odd on opening
    When I want to use Vistitle, and I do a mark in and mark out it used to open with the video layer in the Vistitle window between the marks.
    Now all of a sudden now when I open it, the cursor jumps forward about 10 seconds and shows that piece of media in the Vistitle window.
    Any ideas?
    Mark Twittey
    Walkabout TV
    Edit 1: Custom Built 3XS System, Dual Boot WinXP Pro 32bit/ Win7 Pro 64-bit,
    Asus P6T Deluxe Motherboard, Intel I7 2.66GHz CPU, Nvida GeForce GTX 580 card, LSI Raid controller,
    5Tb WD drives, 12Gb DDR3 Corsair memory, 2 x 27" ASUS LED's, Edius 7.4 & Liquid XE, Boris RED 5.4.0.378, Vistitle 2.5. New Blue Video Est.III
    Hi Mark
    I`ve just tried it using Edius vers 6 & Vistitle 1.6 & it works OK here! I`m in Devon, almost local to you, give me a call if you want, I`m here editing :-)
      Hi
      I'm rendering massive files tonight also.
      Not sure why Vistitle hase started doing this, maybe after a re-boot and cool down it will sort it's self out?
      I'm about to PM you.
      Mark Twittey
      Walkabout TV
        what is the default duration for titles?
        is add between in and out selected or deselected?
          G'day Anton
          Thanks that was the problem the "add between" was not selected.
          All sorted.
          Mark Twittey
          Walkabout TV
            Glad you sorted it out Mark & good to talk with you last night!
