Title blue issues
  • Title blue issues
    Is there a way I can make a bunch of titles then import them into Edius? or do I need to open them one at a time in Titler blue?
    Randy
    If they are individual files with independent names, I don't see an issue.
      Well unless im wrong there is no importer for the new blue files. from what I see Edius wont import newlue title files.
      Randy
        I answered that based on you having NB titler. Its the same for each titler package.
          Sorry Jerry I dont understand. I have NB titler pro 1.X I want to make a bunch (50) pages of titles save them as title 1, title 2 etc. in the NB titlle format then import them all into a bin so I can drop them in various places. I could do that with TM pro but I cant seem to do it with NB titler pro. Is there a procedure I should follow I cant find anything about it in the manual.
          Randy
            Your importer is the actual titler itself. If you are going to use 50 titles, I would make a folder and each title should be saved to that folder. When you want to add the title, open the titler and select file>open. Then navigate to the folder and open the title you want. Once it is in the program, just "X" out of the program and the title will remain. You will have to do this for each title. With 1 or 2 files it isn't a big deal. But, 50 will take extra time.
            Vistitle and Heroglyph 4 drop a file into the project folder which will allow direct import.
            You might want to PM Marcus and see if this feature could be added to a future version.
              Thanks Jerry, thats what I have been doing. I dont do this kind of work often but when I do :)
              Randy
