Vistitle- how to delete plug in effect?
  • Vistitle- how to delete plug in effect?
    Hi all,
    New Vistitle user- I have applied a drop shadow from the plug in effects to a piece of text. I cannot see how to delete it now. Deleting "shadow" on the timelineline takes out the entire text.
    I can go back into the shadow plug in and reset it but it still leaves the effect line in place on the timeline, so there must be an easier way. (prepared to look stupid now!) thanks guys. Edit: delete effect is greyed out
    Rod .
    Rod Pike
    www.voxvideoproductions.co.nz
    A set of high quality paint brushes don't make you Rembrandt!
    Windows7-Edius 6.55-HDspark-VISTITLE v2.5.TMPGenc 5.vitascene v2-mercalli V2-Respeedr v1-Intel core i7 4770 8mb quad core processor-Asus Gryphon Z87 mobo- 16Gb ram-1 x samsung 256gb SSD 840 pro sata-2xWD 1tb sata caviar blue in raid 0-ASUS gtx 760 overclocked 2gb graphics card. Asus DRW 24 DVDRW DVD player-Cameras:Panasonic AC160A and AF102. and an 8kg cat who sleeps on my desk all day.
    double click text to open plugin editor and click reset
    and I assume you know the standard place to add shadow
      Hi Anton,
      thanks for that. I did get that far but I cannot get rid of the shadow plugin. When I reset and save, then recall the text and double click on the text it loads up the shadow plugin again albeit in a null setting. Is there not a way to simply delete this plugin from the text?
      Rod
      Rod Pike
        Watch this video:
        Removing Effect.wmv
          To remove a plugin-effect (like shadow) you have to right click the object and select "remove group".
          EDIUS certified trainer | DaVinci Resolve certified trainer
          Video tutorials for video editing and music production (German)
            Yes, it is right. right click the object, and in context menu, select "Remove group" can erase "plug-ins" effect (like shadow, text path animation, etc..)
              I can remove the effects without a problem, but I am not seeing the 'remove group' menu option that you are referring to. I just hit the delete button and that does it.
              How about a screen shot of the menu with the 'remove group' option showing.
                right click the text box and then you can see the ungroup
                  Hi all, thanks for all the input. The "ungroup" on the standard vistitle screen ( not the plug in screen) works perfectly. This is a bit obscure (to me anyway, and I have the printed out manual!) but thanks to you guys I have a solution as usual.
                  Cheers!
                  Rod
                  Rod Pike
                    I must be dense this morning, but ungroup is greyed out each time I use a title or a shape. I have only seen that option with path.
                      Originally posted by Jerry
                      I must be dense this morning, but ungroup is greyed out each time I use a title or a shape.....
                      You're looking in the wrong direction.
                      Rodpikes question was about plugin-effects, not shader options.
                      If you are applying a plugin-effect (like shadow) to any object in VisTitle, you can remove the plugin by selecting the object and "ungroup" it via right click context menu.
                        Yep, I definitely was barking up the wrong tree there. I misunderstood the question.
