Heroglyph v.4 or NewBlueTitler Pro?
  • Heroglyph v.4 or NewBlueTitler Pro?
    Hi, I'd like to know two things about Heroglyph v.4 and NewBlueTitler Pro:
    1) Which is easier to use and with friendly interface?
    2) Which is better between them?
    I'd like to use one of them with Edius, thanks for some info.
    A lonesome traveler looking for lost tribes around the world: https://www.youtube.com/c/ExploringWorldA/videos
    CPU: Intel i9 7940X
    SSD Drive:
    Why not download the trials and see what you like. I think that is the best way to see what would work best for you.
      Heroglyph 4.0 will give you better realtime performance than New Blue. Vistitle beats them both in realtime performance.
      If you are looking for a titler that does the work for you, choose Heroglyph 4.0. If you want some control over the elements and don't mind rendering choose New Blue.
      If you want full control with a variety of presets and 90%-100% realtime performance with a nominal graphics card, choose Vistitle.
      I would do as Steve suggested. Download the trials for Heroglyph 4.0, NB Titler Pro 2, and the only Vistitle trial is an earlier version ,1.5. Use a downloader for the Vistitle download.
      This way you can test the RT and feature set of each. Keep in mind that Vistitle is at 2.3.1, so there are many, many improvements including free plugins.
        Good reply! I thank you ... but you have missed my 1° question ;)
        I will test their trial to know which is better for my need but I'd like to know the suggestion of someone who know both.
        Thanks again one.
        CPU: Intel i9 7940X
        SSD Drive:
          I have all 3 titlers. Easy is subjective. That is why I gave you an overview of the three and both Steve and myself recommended downloading the trials.
          As I stated before, I use Vistitle for 99% of my work. It sounds like you want a drag and drop titler. If that is the case, Heroglyph 4.0 may very well be
          what you are looking for.
            Thanks again one.
            Well it depends on the user. That's why it is important to try for your self. We cannot tell you which one you will be able to use the easiest.
            Really try them and see what fits within your workflow.
            What is easy for me may or may not be easy for you.
              Do I have to download the 32bit version of ProDAD Heroglyph 4.0.193.1?
              CPU: Intel i9 7940X
              SSD Drive:
                32 Bit for all plugins.
