Superscript or Subscript VisTitle
  • Superscript or Subscript VisTitle
    Hi to all,
    I try to search Vistile help file and all GVG forum and no luck. So, did someone know how to make a font being super or subscript?
    Thanks,
    Josip
    Originally posted by RoseART View Post
    Hi to all,
    Thanks,
    Josip
    For subscript, just double click the text object, and enter into editing, select the characters, adjust this characters font size to smaller.
    For super, there is a work around way to do. Create a smaller text object with this super character, and put it to your wanted position.
      Thanks for fast reply,
      Scroll-crawl titles works well, but how to link two objects (still page) and have the same animated motion?
      Sincerely,
      Josip
        Sincerely,
        Josip
        Do you means let them have same 3D transformation ?
        Select them, and "Ctrl+G" to group them, and then adjust this group's 3D transformation.
