mts to mts ?
  • mts to mts ?
    Hi everyone.I have 1 question.How can someone convert an mts file to an mts just adjusting for example mts 1920X1080 to mts 1440&1080?
    please any idea?
    I5 4690 CPU
    MOTHERBORAD GIGABYTE GA-Z97-HD3
    RAM 8GB [email protected]
    AMD RADEON HD 6800
    2X2TB WD CAVIAR BLACK (RAID 1)
    2X2TB WD CAVIAR GREEN (BACKUP)
    1 OCZ SSD 128GB
    Windows 7
    Edius 9&8 Workgroup
    Put the 1920 file on a 1440 timeline and export it.
    But why do you want to do that?
      In fact a friend has a pc that it is not so fast and when he import files 1440X1080 he can work really good and fast but with 1920X1080 his pc pauses a lot during work.He is looking for a converter to do that.not from edius cause then he has to export every file one by one.
      If anyone has any idea of such a converter I would be greatful!!!
      thank
      George
      I5 4690 CPU
      AMD RADEON HD 6800
      1 OCZ SSD 128GB
      Windows 7
      Edius 9&8 Workgroup
        με το tmpgenc mastering
        εξοδος απο το edius σε canopus hq απο το υπαρχον εργο και εισαγωγη στο
        tmpgenc mastering
        SUPERMICRO 7046T-NTR+ CPU DUAL XEON X5680 3.33 GHZ nVidia Quadro K2000D 2GB DDR5 32GB OF RAM WINDOWS 7 x64 ULTIMATE 8TB SEGATE RAID 1 & 8 ΤΒ WN STUDIO II MY BOOK RAID 1 & 8TB e-sata RAID1 CANOPUS SP FOR HDV FIRECODER-BLU EDIUS 5.5 EDIUS 6.08 EDIUS7.03 ADORAGE IMAGINATE 2 BD LG PROCODER 3 CANOPUS STUDIO CONTROL BOX PANASONIC AG HPX301 P2 AVC INTRA100 AJ-PCD20 P2 DRIVER PANASONIC VIDEO AJ-D250 DVCPRO CAMCORDER AJ-700E DVCPRO AG-HPX250Ε
          thnaks zanettos!!!
          I5 4690 CPU
          AMD RADEON HD 6800
          1 OCZ SSD 128GB
          Windows 7
          Edius 9&8 Workgroup
            I have TMPGE 5 and love it. But, if you are looking for a free version, you can download the AVCHD conversion program from the registered users section under utilites.
            I think it may do what you are after for free. There are settings for everything. All you have to do is set it up and then drop the file onto the droplet and it goes.
            You will notice that it also converts to other codecs. If the AVCHD file is bogging down Edius, why not convert to HQ and keep it at 1920x1080? Performance will still be better
            than 1440x1080 avchd.
            Here is a screen shot of some of the controls:
            Keep in mind, it is free!
              cool Jerry.thank you so much!!!
              I5 4690 CPU
              AMD RADEON HD 6800
              1 OCZ SSD 128GB
              Windows 7
              Edius 9&8 Workgroup
                Dear Jerry I have downloaded the avchd and it gives me this result.
                what codec am I missing?
                I right clip the mts file and then i choose convert with avchd.
                I5 4690 CPU
                AMD RADEON HD 6800
                1 OCZ SSD 128GB
                Windows 7
                Edius 9&8 Workgroup
                  Try it the way I do it in the video:
                  MTS to MTS.wmv
                    will try it in few...thanks Jerry
                    I5 4690 CPU
                    AMD RADEON HD 6800
                    1 OCZ SSD 128GB
                    Windows 7
                    Edius 9&8 Workgroup
