Two effects I've tried (Shadow Drop and OUTLINE from VE4 and VE5) don't seem to work in Edius 6.5 and I'm not sure why. I take something really simple like a line of text, save it as HQ with Alpha. Try to apply the OUTLINE effect and nothing yet on the same clip it works beautifully in After Effects. Is it something I'm doing wrong or is it something with Edius's handling of alpha channel? Or is it New Blue's Edius implementation that's problematic?
New Blue Alpha-based effects don't work
Last edited by chappyware; 03-07-2013, 12:38 AM.Gigabyte mobo with i7 K2600, 16G Ram, Storm Mobile, nVidia 570 but I'm just a hobbyist.Tags: None
Jan
Works here OK!
the project setting needs to have alpha enabled as wellAnton Strauss
I noticed you have keyframes enabled in NB filter, I always disable3 that before I apply a preset
your settings appear fine
can you make sure the clip accepts drop shadow with the layouterAttached FilesAnton Strauss
Solution Found!
I clicked the "I" icon in the new blue dialog and selected UPDATE. Turns out all of my New Blue plugins were not the latest. After updating, I re-opened Edius and the outline effect was there as soon as the program opened that project!Attached FilesGigabyte mobo with i7 K2600, 16G Ram, Storm Mobile, nVidia 570 but I'm just a hobbyist.
Originally posted by chappyware View PostI clicked the "I" icon in the new blue dialog and selected UPDATE. Turns out all of my New Blue plugins were not the latest. After updating, I re-opened Edius and the outline effect was there as soon as the program opened that project!
