3rd party plugins Crashes Edius 6.52
Zorro
What brand of memory, I have seen 3 systems here all with Corsair memory, different mother boards and all exhibit the same problem of freezing, white screen or just plain lockup
All have been fixed by using manual settings on the memory and setting the memory to normal not turbo
There have been others on this forum who have also experienced the problem and fixed the same way
2 Sticks running in dual mode also fixes the problem, could be there are some faulty memory sticks out there, memtest does not find a thing no matter how long it is run
Something to keep in mind if you ever run into it, I have not heard from anyone without the problem but I would not expect to, its only when there is a problem that people complain
Now the X58 chipset is old hat and the manufacturers have gone away from tripple chanel (I wonder why) the problem probably won't re appear
REgards BarryWin 10HP, EDIUS WG9.4, HD Spark, Boris RED 5, VMW6, Authorworks 6, Bluff Titler, VisTitler 2.8, NEAT 3/4, Mercalli 2/4, Vitascene, Izotope RX6 Plugin, NewBlue, Trend Micro AV
Laptop ASUS G752VT-GC060T Win 10HP, Edius WG8.53 Samsung M2 SSD 256G+1Tb HD,Comment
I'm running a matched set of 24 gigs of Corsair Vengeance 1600 ram.
It is on an Asus Sabertooth X58 motherboard. It is rock solid.Jerry
Main System:: Azrock z690 Taichi, [email protected], 64gb ram, Lian Li Galahad 360mm in push pull, Lian Li 011 Dynamic XL ROG case, 13 Lian Infinity fans, Win11 Pro , Samsung 980 1tb boot NVME, 2TB Sabrent M.2 NVME, 2 TB WD 850x NVME, 1TB Samsung SSD, 12TB Raid 0, BM MINI MONITOR 4K, , Dual LG 27GK65S-B 144Hz monitors, GTX 1080ti SC Black Edius X.
Second System: EditHD Ultimax-i7, X58, [email protected], Corsair H80, Win764, 24gb ram, Storm 3g, Samsung 840 Pro 256, 4tb and 6tb RAID 0 on backplane, GTX 980ti Classified, Edius 9.55, Apple 30", Samsung 24", dual BD.Comment
All Ok now
Having put server RAM in the HP Z800 which is 24Gig ECC registered and updating to Edius 6.54 all plugins work no poofing off with error.
There is still white windows when loading with all the plugins in the folder, and if there is a window open on the extended monitor it stays in front of Edius until clicking anywhere in the Edius project, at least that is only an opening issue.Sys4: Edius9/XWG ASUS Z10PE-D16WS MB 2xE5-2696 Xeon 72 cores. 16TB RAID0 64G RAM RTX3090Ti. Samsung 55" QLED 1500 NIT HDR 4K TV. Storm3G Elite/Decklink 4K 12G HDR. Yamaha RX-A870 A/V 7.1 audio. Sys1-3 Edius 8.5 WG + RX-E1+HDBX1000 MIP HP xw8600 2 x X5492 CPU 8 cores, 8G RAM, GTX1080TI. All sys Fibred to central media pool - 5TB RAID + QLogic Fibre Switch. Central SD Pro VCR rack. All sys YUV & audio to theatre with Sony STR DN1040 7.1 audio amp with 1000W sub 63" HD 3D Samsung TVComment
