3rd party plugins Crashes Edius 6.52
  • 3rd party plugins Crashes Edius 6.52
    Heroglyph 4.0198 instantly crashes Edius. As soon as the H banner appears Edius has stopped working message appears.
    Any ideas?
    Faulting application name: EDIUS.exe, version: 7.0.2.13, time stamp: 0x50786728
    Faulting module name: ntdll.dll, version: 6.1.7601.17725, time stamp: 0x4ec49b8f
    Exception code: 0xc0000374
    Fault offset: 0x000ce6c3
    Faulting process id: 0x2ea8
    Faulting application start time: 0x01ce08b172513dfb
    Faulting application path: C:\Program Files (x86)\Grass Valley\EDIUS 6.5\EDIUS.exe
    Faulting module path: C:\Windows\SysWOW64\ntdll.dll
    Report Id: f39f4e36-74a4-11e2-b28f-78acc03c2f0a
    Also Gen Arts Sapphire Scan lines is Ok but ditto Vignette crashes Edius.
    HPZ800 dual 6 core CPU 24GB RAM win 7 64Bit
    Also Izotope Ozone (recommended replacement for old Izotope bundle) crashes Edius if I double click filter whilst time line is playing
    Looking at your system specs you have tripple channel memory (nothing to do with DDR3) this is the memory configuration
    Windows 7 seems to have problems with this and especially with Edius 6.5
    Go into your BIOS and make sure anything to do with memory marked TURBO or AUTO is removed and set to manual
    Also make sure HPET timing is set to 64bit (Could be in Power settings)
    I had similar problems till set up as above now as smooth as silk
    It didn't take long for the tripple chanel to be replaced with Quad channel, but no one is confessing to the problem
    Hope that helps
    Regards Barry
      Maybe it is something with the system.
      Genarts and Heroglyph work here.
      There is a note in the compatibility thread that on some systems it could happen that if you have NewBlue plug-ins installed Heroglyph and Sapphire crash.
      You can try the following if you have NewBlue filters installed cut the NB folder out of the Edius plug-in folder. Check if SA and Hero work correct. If so then you know what he issue is.
        Identify Crash causes.
        Firstly thanks for the replies.
        I have a full stack of plugins FEC, GenArts, NewBlue all, Izotope and ProDad. No sign of Adorage for Edius 6.5 yet so its just Vitascene and Mercalli.
        Tried turning off the Intel turbo options in the bios Barry but that had no affect still crashing. Not sure that any settings below that I have available affect that.
        Memory/chipset
        Memory mode interleave was disabled lots of stuff on that left unsure.
        Numa split mode was enabled
        Hardware Power Management
        Intel Turbo boost was enabled (Effectively temperature monitored overclocking)
        Enhanced turbo boost enabled
        EUP compliance enabled (everything off on MB)
        So I will strip out the plugins folder and park off on the deskop the full set and introduce steadily what works. The big question is of course if there is a big incompatability who does one point the finger at for a fix?
          Sorry I can't help with pointing fingers. I just suggested something which would allow you to use Genarts and Heroglyph.
          The issue is a bit complicated and we are also investigating. But as you can imagine it will take sometime to sort as we have been getting more and more plugs .
            NewBlue Plugins results report
            Test condition: 1920 1080 50i project NewBlue plugins none.
            Create Heroglyph 4 title and park up the cursor over the title.
            Save project & close Edius
            Introduce New Blue plugins on the logic of choosing the ones originally set for the original Edius bundle first.
            Open & test. OK save and close
            Now add all the video essentials plugins 1 to 6.
            We are still OK. Save & close.
            Now if any of the following NewBlue plugins are added, Edius 6.52 opens, then pauses a moment, then crashes, without touching the mouse or keyboard.
            ColorFast
            Flash Remover Pro
            Light Blends for Windows
            Light Effects for Windows
            Titler for Windows
              It depends because there are combinations (on affected machines) in which the plug-ins you pointed out work with Sapphire and Heroglyph. As I said it is a bit more complicated. But thanks for testing and reporting. :)
                Complications...
                Well yes we have:
                A hardware platform (MB & PSU)
                Third party plug in cards
                RAM manufacturers
                CPU manufacturers
                OS from Microsoft
                The main App
                App manufacturer hardware
                Third party plugins
                Stir it all up, put it in the oven and expect the cake to be perfect after baking.
                There is always going to be combinations that are flakey with this set of ingredients. Always frustrating at the coal face at the user end (me) but sometimes difficult to nail down what the problem is in the app, (software designers) and repeating the problem.
                As you say I can only report on my results in my situation. I hope in some small way it is a help. I look forward to 6.55.
                  Latest Plugins
                  Both the ISP*.tpi and NeatVideo.tpi cannot co-exist with the other plugins in my set up and Heroglyph
                    Weirder and weirder
                    System 4 Edius 6.52
                    Just got Adorage working and now the set of New Blue I had before Adorage was added doesn't work.
                    Also no one plugin is faulty it is the combination of NewBlue plus Sapphire plus ProDad filters that causes Edius to crash.
                    All of them will work but only in certain groupings.
                    That is about as much as I can do, it's over to the software engineers..
                      nVidia Driver 311.15
                      Now Edius its better with this latest nVidia driver. 2 off FX3800 GPU (noted Direct X 11 installed GPU have direct X 10 support).
                      Now see we have 314.07, driver released 18th Feb will try that next. Report on 311.15 below;-
                      Ghosting in filters window whilst scrolling up and down filters list gone.
                      White windows gone.
                      Now can add more NewBlue plugins without Edius crashing.
                      So, with Sapphire, and ProDAD Adorage,Vitascene, Mercalli, Boris Red, Izotope Ozone VST, Vistitle, Final Effects Complete (Adobe aex), everything NewBlue except the following
                      Titler Pro
                      Light Blends
                      Light Effects
                      Flash remover Pro
                      Although the above will work but have to remove some others. Almost like there was some sort of plugins limit.
                      It still crashes out with the others added:
                      Faulting process id: 0x222c
                      Faulting application start time: 0x01ce0effd583a3ee
                      Report Id: 679bbd79-7af3-11e2-a1f4-78acc03c2f0a
                        Thanks for reporting.
                          posting
                          Can you tell me how in the world I post a quote..I see no where on the forum where/how I can post a quote...am I missing something?
                          Andy
                          [email protected]
                            Look in the bottom right corner of the post. Click on the Quote button
                              Third party plugins update.
                              Ok so now we have Edius 6.53. This reduced the number of New Blue plugins that I can have at one time in the plugins folder against v6.52.
                              Test project 1920 by 1080 50i 10Bit with mixed material on timeline.
                              Cursor parked on ProDAD Heroglyph template title.
                              I have put Nvidia Quadro Fx3800 driver 311.35 which is the latest.
                              ProDAD products:
                              Adorage
                              Mercalli
                              Vitascene
                              Boris Red 5
                              Izotope Ozone series
                              MDA dynamics
                              T-Sledge
                              GenArts Sapphire (latest)
                              AEX
                              Final Effects complete 6-4 & 6-5
                              BCC4 Boris
                              The following work ok
                              1 Art Blends
                              2 Art Effects
                              3 Film Effects
                              4 Motion Blends
                              5 Motion Effects
                              6 Paint Blends
                              7 Paint Effects
                              8 Video Essentials
                              9 Video Essentials II
                              10 Video Essentials III
                              11 Video Essentials IV
                              12 Video Essentials V
                              13 Video Essentials 6
                              One more can go in before Edius starts up loads the GUI then poofs to the desktop with create system report.
                              The following cannot be added with those above
                              3D Explosions
                              3D Transformations
                              Titler for Windows
                              Flash remover Pro
                              I tried adding two more folders with the contents empty and that still works so its not the number of folders that is the issue.
                              So adding 3D explosions and 3D transformations it poofs.
                              So now remove all but one .tpi entry in each of the 3D folders and it still poofs. So I can't see what the issue is, but there clearly is one.
                              Faulting application name: EDIUS.exe, version: 7.0.3.178, time stamp: 0x511cafb6
                              Faulting process id: 0x1ff0
                              Faulting application start time: 0x01ce1e8aec3a6efc
                              Report Id: 545f8bd8-8a7e-11e2-a5e7-78acc03c2f0a
