Vistitle 2.3 now available
  • Vistitle 2.3 now available
    An update to Vistitle 2.3 is here:
    There are a list of some new features on that page
    Check out the new tutorial, also:
      Vistitle help me
      Hi,
      You are used Vistitle for I asked bit: I want to buy software Vistitle 2 for EDIUS 6, where there is selling and how much (I was in Vietnam).
      - I install Vistitle version 1.5 trial, my purpose is to make the subtitles on EDIUS. In this trial I import a text file allows only 10 lines of subtitle display,
      and I want to import a lot of subtitle streams so the official copyright Vistitle do?
      - When I edit multiple lines of subtitles, how to zoom the timeline in the subtitle window (slider)
      thanks
        Originally posted by chimtroi2 View Post
        Hi,
        According to the Vistitle website, this is your reseller in Vietnam:
        BMTS Ltd.
        P602 17T9 Trung Hoa - Nhan Chinh,
        Hanoi Vietnam
        Tel: 84-4-2815153
        Fax: 84-4-2815144
        Web: www.bmts.com.vn
        Email: [email protected]
        On this page are video tutorials which might help. There is one about subtitles:
          thankfully your assistance, is there your rightness go through taken vistitle 2.1: can you test direct in your vistitle2.1:
          in vistitle 1.5 trial I import a text file allows only 10 lines of subtitle display, and I want to import a lot of subtitle streams so the official copyright Vistitle do?
          thanks
            thanks
            1) Yes, VisTitle full version support import unlimited lines of subtitle.
            2) Keep right mouse down and then move mouse, it will zoom timeline.
              ok, thanks
              so I can't find any shop to buy Vistitle in Viet Nam. Help me?
                I have a question from a guy : is Vistitlte 2.3 compatible with Edius 5 + XP ?
                Marc
                System : W7 Ultimate - MB: Asus Z170 - I7 6700K - Ram 16 Go - SSD1 256 Go (OS/log) - SSD2 1To (rushes) - HDD 4To (save) - Nvidia Asus GTX970 - HDspark - Edius WG 9 - Vistitle 2.6 - Robuskey - Mercalli4 - Neat video - Ignite - Hitfilm4Pro - AV : Eset Nod32 - Others : Moniteur Sony 32-EX500 - Cam : Sony EX1-R - 2 x Sony PXW-X70 - 1 x Pana GH5
                Edius in France
                  Marc
                  Of course, it compatible with EDIUS 5.x, 6.0x, 6.5x in XP, Win7.
                    ok, thanks
                    If you are still having a problem finding somewhere in Vietnam to buy Vistitle, perhaps you could try buying on the internet? See the second post here:
                      http://forum.grassvalley.com/forum/s...ad.php?t=29197
                      I took John's advice and had my serial code for Vistitle in 1 or 2 hours.
                      Tony
