Need help vistitle
  • Need help vistitle
    Hello.i have a major problem with vistitle.I installed him and when i open him it can see the titles from projects but when i look at the effects layouts text effects movies images and the rest of them they are empty.on the screen if i open an old title maked before re-installing vistitle he can open that title and he play it (with all efects and movies inside) but in movie box or text effect or layout box is nothing.is empty.I do'nt understand why?I maked update and anything but makes the same problem
    What version? Can you try reinstalling as an administrator?
      What's version is your VisTitle ? It seems that you are using VisTitle 1.5x or former version ? The administrator rights is necessory for that version to fix the problem about preset library is empty.
      Please upgrade your VisTitle to 1.87, which had fixed these problems.
      You could access www.vistitle.com to download it.
        i solved the problem.very useful advice.i have edius 5 and vistitle 1.54.but i can't upgrade vistitle.i can to the version 1.6 but from there, vistitle is not recognised by edius and he don't want to run from that version.
        Another problem!!! How can i change the format that is burned to dvd?on dvd apears VOB but a lot of people told me that they can't play the dvd.It goes a little time (20 min) and from there the dvd players try to read and it goes in frames and again read and again frames.at me on the pc it works very good with no stops.i need to know how to change the format when the dvd is burned.i have try to make image and then to convert with some converter but I can't convert the menu.And the menu part is very important.
          You could download VisTitle 1.86 full installer from here:
          http://www.vistitle.com/ListDownLoad.asp?ID=43
          Uninstall your old VisTitle, and then install this full version.
            I discover new things now.When I put effects between video parts now he don't play the effect.The cursor goes over him but nothing hapends.Just like the effect is not there.I didn't have this problems before because the settings have been made by the guys who had sold me the pc in Italy.but now i can't find that settings to make work normal.Can someone help me?
              VOB is the correct format for file on a DVD
              They should sit inside a "VIDEO_TS" folder on the disk
              Problem could be
              Burning at too fast a speed, slow down to 1 or 2x not MAX!
              Disk brand could be inferior, a lot of faulty disk out there
              What did you use to burn the DVD, Program / Burner model??
              See Here
              http://www.digitalfaq.com/reviews/dvd-media.htm
              When you say you tried to convert? to WHAT? with WHAT?
              Makes no sense
              Your last problem "The cursor goes over him but nothing hapends.Just like the effect is not there" Could be tied up with settings for Edius
              Go to Settings<>User Settings<>Preview<>Playback and make sure "Combine Filter Layers and Track Layers" is selected
              Regards Barry
                Sorry if I've created problems.I don't have expirience in posts.I burn at 4X just verbatim discs.IT's the slowest speed i have at edius(burn to disc).I have two units of burning, bowth LG (one is Bluray) but bowth make the same thing.about converting, I've tried to convert that VOB files to divx with Divx plus converter.It works just for video but he can't convert the menu.It is interesting that, at some people all is fine and work great.
                  what is the bitrate you set in diskburner?
                  7700 should be the maximum for video and 256 for ac3 audio
                  do not leave disk burner on auto bitrate, otherwise on short projects, it may choose bitrates of over 9000 which is a big bo no for burning
                    please help me to understand where i can find settings for bitrate and how can i set them?
                      Here is a screen shot to help you.
                      You will notice that I chose cbr. This is fine. If you want to use varible you can do that also. It just depends on what you need.
                      Next time start a separate thread for a different topic within an existing thread. In the long run, you will be helping others with your same question
