Titler Pro 2
  • Titler Pro 2
    When closing Edius down I get an error message after it shuts down in windows 7 64bit, the faulting Module is managerGL.dll anyone else had this, I have even tried the new Beta version that was sent to me today and same thing.
    anyone at all see this error that has titler2 Pro installed? Come on!
      Steve,
      I'm very sorry for the issues that you're having with Titler Pro 2. Just to make sure, are you only getting this error when you close Edius? Does it happen at all when you are using Titler Pro 2?
      Can you tell if this is causing any issues with your projects, or with Edius itself? Or, does the "crash on exit" not seem to be causing any other problems?
        Hi, It happens only when I exit Edius, the programme seems to work ok in Edius, i just a reply back from Support and this is what he said:Personally, I would leave it installed, use it, and ignore the error on exiting.
        I currently have the programme uninstalled, and as i said to the support tech for the price people pay for software these days you think that it would work ok and not give errors ect. i am not real happy at all since i bought this programme i have had it installed and uninstalled that many times, also if you have TMPGEnc mpeg 2 plugin installed Edius crashes and also titler 2 Pro crashes and you have a white window with nothing in it when starting Edius.
          Do you also have Titler pro one still installed?
            no just had titler Pro 2 installed, have never had version one installed, happens everytime i shut Edius down, faulting module: managerGL.dll
              Honestly I don't have this issue but I don't have TMPeg installed.
              Is you firewall or virus scan blocking it?
              The reason I asked if you had version one installed is that there is instability when you have both installed as a plug in EDIUS in certain situations. So we don't recommend having them both installed at the same time.
              Note :I did a search for managerGL.dll but I have it on my system. I don't get the crash
                I am finding this happening without TMPGEnc mpeg plugin installed, and never having version 1 installed.
                  can you list all 3rd party plugins you have including VST plugins
                  something is clashing
                    The only Plugins installed Anton are Izotope Ozone 5 Advanced, and Izotope RX2 Advanced as VST Plugins, But I have tried with these removed and still getting the error when exiting Edius, which says fault module: managerGL.dll
                      you don't have any newblue? vistitle? prodad?
                        Sorry anton yeah Vistitler only as well.
                        steve
                          Steve, I own a copy of Titler pro 1 and downloaded a trial of 2 and got a similar, if not the same error on exit.
                          I found that 2 was not that much better than 1, which is frustrating enough on it's own, so ended up deleting version2 and no more error on exit.
                          Given up on all these plugins and got After Effects CS6. Steep learning curve but blows most others out of the water.
                            Are you still running the Nvidia 310 driver? I don't know if that would give an issue, but, it is worth rolling back to 306.97 to try it out. Did you get this same error with Titler Pro 1? I had major issues when both were installed. I uninstalled both separately and reboot each time. Then I re-installed my version 1 and it works fine.
                              Never had version 1 installed.
