Edius Crash with Titler2 & TMPGEnc MPEG 2 Plugin
  • Edius Crash with Titler2 & TMPGEnc MPEG 2 Plugin
    Edius crashes with Titler2 & TMPGEnc MPEG 2 Plugin in stalled together, I had installed both and noticed a white window when opening Edius 6.52, I uninstalled the TMPGEnc Mpeg 2 plugin and it sought of worked, still had and error come up after closing Edius down, the error is related to NewblueFX Titler 2 Pro latest version, also noticed that Edius is still running and does not shut down after you close the programe off with Titler 2 Pro installed, i hope that Newblue fix this as i just purchased this programe last night and i am not very happy at all, not when you cant use it!
    Hi Steve,
    I apologize that you're having trouble using Titler Pro 2.0 and TMpegEnc together. Unfortunately, we haven't had anyone report this issue before so I don't have anything to suggest off the top of my head.
    Have you contacted our support department yet? We definitely want to look into this issue.
      Have spoken to support about this,I can't really see a fix for the problem myself until they release a new version, also to fix problems like Edius still running in processes after you shut down when you use Titler 2,
