I evaluated the Genart sapphire 6.14 under Edius , full functionality with presets!,
  • I evaluated the Genart sapphire 6.14 under Edius , full functionality with presets!,
    Genart sapphire
    New in Ver 6.14:
    Fixed problems with the Flare Designer and Preset Browser on non-English systems.
    SwishPan now applies motion blur correctly when the transition goes backward.
    Preset Browser: fixed problems installing preset packs (.gpz files)
    Corrected some parameter ranges for Quantel.
    Flare Designer: fixed a bug that prevents saving when run as a standalone application.
    Preset Browser now starts up faster and is more responsive overall.
    LensFlare Autotrack: Occlusion now works correctly.
    As I mentioned , although it has 32 bit plugin especially for Boris Red, but it could be loaded under Edius,too !
    In accordance with my DIY experience, I accomplished GenArts Sapphire 6.14 under Edius 6.52 , with full functionality, including its presets as well .
    It's a perfect Edius plugin, enjoy...
    Sorry . There is a lot of instability when you use Genarts via Boris.
      I moved such Genart sapphire 6.14 plugin to Boris FX 10, then try to load it under Edius...
      First , in Edius timeline, add a filter of Boris FX 10, then load Genart sapphire 6.14 in the menu of Boris FX 10 .
      It works, too. And it's stable more than Boris Red, I think. I am testing now.
        Demo video , here it is...
