Reuse a TMPGENC Video Mastering project
  • Reuse a TMPGENC Video Mastering project
    I use a TMPGENC project to convert HD to SD :
    - input file : MPEG HD
    - output file : SD 720 x 576 - elementary stream
    I launch it the first time to create an output file.
    No problem.
    After that , I modify and increase the input file : duration 10' to 15'
    And again I launch the same project, but the ouput file = 10' (and not = 15')
    I use a workaround by creating a new project !
    Probably, there is a better trick ...
    Marc
    System : W7 Ultimate - MB: Asus Z170 - I7 6700K - Ram 16 Go - SSD1 256 Go (OS/log) - SSD2 1To (rushes) - HDD 4To (save) - Nvidia Asus GTX970 - HDspark - Edius WG 9 - Vistitle 2.6 - Robuskey - Mercalli4 - Neat video - Ignite - Hitfilm4Pro - AV : Eset Nod32 - Others : Moniteur Sony 32-EX500 - Cam : Sony EX1-R - 2 x Sony PXW-X70 - 1 x Pana GH5
    Edius in France
    Mark
    Open the Project
    Delete the file and bring it back in
    or
    Go to Edit and drag the end of the file to comply with the new length
    If it is shorter the quickest way is to cut
    VMW remembers the size originally brought in
    Regards Barry
      start a new project, add the new clip, apply the template you saved, it can't get faster than that
      I even have the filter template loaded automatically that eliminates the black pillars
        that's exactly what I usually do.
        But, it seems the Bluetongue solution is faster :
        "go to Edit and drag the end of the file to comply with the new length"
        I was thinking something more simple (settings, ...) but apparently it does not exist.
        Thank for the workarounds.
        Marc
        Edius in France
