adobe encore
  • adobe encore
    ive been using dvd workshop for years and its time to upgrade, how good is encore and is it pretty easy to to the chapter/menu routine? dvd workshop is so simple but antiquated
    There is a somewhat stiff learning curve if you are not familiar with other Adobe products. I usually have Encore, After Effects, and Photoshop open at the same time. I have used it since V1 and really like the program. Just create the proper supported file from Edius and import it into Encore and you will not get a re-encode. I make all of my menus from scratch in Photoshop.
      Jim
      Have a look at DVD Movie Factory Pro, it has come a long way from the original, has many Java interactive menus for Bluray that can be toned down to look good, similr to DVD Workshop
      Make sure you set your templates to a higher bit rate than you supply it or it will re encode
      Or try Authorworks from TMPgenc
      Both are available for trial
      REgards Barry
        I used Encore until it ceased to be a stand-alone product - now you can only get it as part of Premiere, and I have not used it lately.
        Then I switched to DVLAB Pro and Authoring Works. In my opinion AW is far and away the easiest to use to produce DVD and BluRay as long as you are not trying to do something out of the ordinary.
          I have always liked Encore's workflow the best but I stopped using it at CS5. Bringing in Blu-ray assets and exporting images just took forever. Also the Blu-ray size did not match the projected size. Just seemed like Adobe forgot Encore in that stretch of time...
          So I moved on to Authoring works. It is much faster working with assets and images, but it is a totally opposite approach. In Encore you can build stuff from stratch and fit it to your assets. In AW the assets dictate everything. Chapter points are rigid and determined by your assets. For simple or non-menu work AW is great. For complex menus you need to work backwards from the encoding stage and I do not care for how restrictve it is.
          I might check out CS7 if there is wind of Encore being improved and if Premiere has a better multicam to warrant the purchase.
          Edit: Just had a look at Adobe's Encore forum and there are a lot of posts about issues. They may be user error but Encore does not seem to be the focus of the Creative Suite.
            CS6 has corrected the long import time. It seemed to take longer with files created by Edius. When I went to NAB to test this at Adobe, I did not have my file with me. With the help of Jon Geddes, from precomposed.com, I was able to determine that the import times issue had been fixed in CS6.
            The space overhead issue is still there. I think it reports about 2-4gb extra when creating a disc. MPEG handling really improved in the CS5.5 version.
            If you are wanting to create a full featured interactive menu, Encore is still your best bet short of DO Studio.
            Go to:http://www.precomposed.com/
            Look at the full blown sets that Jon creates.
              Encore is very elaborate with good integration with After Effects and Photoshop for really fancy menus etc. Has no audio waveform so is not as easy to use as DVDArchitect unless you set chapter marks in Premiere.
              Ron Evans
              Ron Evans
                One great thing about Authoring Works is it will read marker exports from Edius. Encore does not to my knowledge. I do not know about other packages.
                  I used marker export a lot when it was only DVD and authoring was in DVDLab. Since I now do almost all authoring in DVDArchitect I have not bothered trying. It is easy to set the markers and name them in DVDArchitect and then I can get it to create the menus for me too. The audio waveform is very good in DVDArchitect so it is easy to see where music or loud noises are to quickly get to points of scene changes or dances. Unfortunately not possible in Encore without going through Premiere as there is no audio waveform in Encore something that is continually asked for in the forums. I think the advantage of DVDArchitect or Encore is a lot more control over how the menus are created and operate. Once you get used to full manual control its difficult to go back to some thing that creates things for you and doesn't allow much changes. I too create background for menus etc in Photoshop or Photo Brush and like the ability to control how the DVD looks. I could never get AW to do what I wanted or for that matter disc creator in Edius.
                  Encore and DVDArchitect you can start with a clean sheet and build with individual items. Lots of control of how the DVD looks and how it operates. They also both have styles or themes for menus that will auto create the DVD for you in the same way that the simpler programs will. The difference is that they can then be completely edited manually to look just the way that you want by adding or deleting items and changing shapes or backgrounds. There is a learning curve of course but well worth the effort.
                  Ron Evans
                  Ron Evans
                    If your a rookie with Encore I suggest buying some of Lance Grays template (pop ins or pop drops or whatever) they are really nice Encore templates and take half the work out of making DVDs.
                    Randy
                      Pixel Pop-Drops are reasonably priced and can be modified in Encore and in Photoshop.
                      These are basic templates that are easy to use and are very quick. I guess Lance gray designs these....not sure.
                      http://www.pixelpops-shop.com/DVD-Me...tes_c_172.html
                      If you are going for something to 'knock their socks off,' Jon Geddes at precomposed makes full motion, fully interactive, multi panel templates. These use AE, Photoshop, and Encore for modification.
                      These are a little more expensive but have the 'wow' factor.
                      http://www.precomposed.com/products/
                        yeah those are Lances there nice. I am looking into stepping up to the precomposed line though.
                        Randy
