Vistitle i just got the box with cd and dongle but will not load to my ed 6.5
  • Vistitle i just got the box with cd and dongle but will not load to my ed 6.5
    Need help with vistitle installing to my 6.5 it 6.61 now i think.
    It give me a message saying you must install edius first so i was thinking i must down load from there web site to installed the full version for the 6.5.
    Please any one will help thanks.
    AMD Ryzen 9 3900X 3.8GHz [4.6GHz Turbo] 12 Cores/ 24 Threads 70MB Cache 105W Processor
    SSD: 512GB Intel(R) 660P SERIES PCIe NVMe M.2 SSD
    850 power suply
    32GB (8GBx2) DDR4/3000MHz
    ASUS TUF X470-Plus Gaming AM4 ATX
    EVGA GEFORCE RTX 2080 SUPER GPU
    Windows 10 Pro
    HDD: 8TB (8TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPM
    This is not going to change anything, but go ahead and update your Edius version to 6.52.
    Now, which version of Vistitle did you purchase?
    If you purchased V1,
    Go to this page and read about installations:
    http://www.vistitle.com/listNews.asp?ID=17
    This is the full 2.0 Installer:
    http://vistitle.com/listdownload.asp?id=44
    This is the 2.1 update:
    http://vistitle.com/ListDownLoad.asp?ID=48
      visttiles installing on my 6.5
      Hi jerry i must have vis 1 so i need to instaled that full version 1.86 first and use the serial and dongle with the one that came in the box.
      ok will try thanks.
      Will i need to keep installing the other ones up to the 2.0?
      850 power suply
      Windows 10 Pro
        you get the free upgrade to V2, make sure to do this first and you shouldn't have to worry about installing V1 at all.
          so skip the 1.86 ad go to 2.0 than 2.1 for ed 6.5
          ok i will try that tomorrow thank for all who help
          850 power suply
          Windows 10 Pro
            2.0 is the full installer. 2.1 is an update installer.
              Jerry now it telling me to get the activation serial number for the 2.0 i call local dealer they don't know than i email vistitle to see if i can get the serial no.
              Is that how it works. so hard to installed.
              thanks
              850 power suply
              Windows 10 Pro
                Yes, you are going to need a new serial number to be able to install V2.
                The reseller should be in charge of this. But, if they decided to walk away at this point your only recourse is to contact Vistitle. Also, I wouldn't purchase from them again if they leave you hanging
                Do not use the serial number off of the dongle. You will need to install 1.8x and then hit cntrl + F1. This will bring you up to a splash screen that says 'copy serial number.'
                Do that and paste it to a notepad or text document. That way you will have it. Now, being that it is new the number on your dongle might match the serial. But, don't always count on that.
                Push the reseller to try to get the serial number. If they won't support it you could try to return and order from another vendor such as: http://www.sharbor.com/vendors/VID.html
                I don't know what you paid for the product. So, this is just an example of where to order.
                  Jerry i call the store where i bought from they can not help me so they will take it back if i don't get a response from vistitle by tomorrow. That link you gave me it same price but i have to pay sale taxes. I may just go for the Tile Pro from newbluFX
                  So far no email response from vistitle yet.
                  850 power suply
                  Windows 10 Pro
                    They are asleep now.
                      Yes it in China i forgot i will wait till sunday
                      850 power suply
                      Windows 10 Pro
                        This is normal, Vistitel 2.x is a pay increase. Download 1.87 must
                        Edius 9WG, vistitle, Tmpgenc Authoring works6.
                        Matériel informatique: MB MSI Z370 SLI PLUS / i7 8700K / 16 Go DDR4 / Intel HD Graphics 630 - NVIDIA GeForce GTX 1060 3 Go - Système SSD: Samsung 960 EVO M.2 PCIe NVMe 250 Go.-SSD 500Go pour un montage rapide. -2 boîtiers externes 4To Raid0 etc ... Carte BlackMagic Shutle (USB3)
                        Matériel de diffusion: deux moniteurs AOC 24 "Projecteur Panasonic PT-AE 3000E
                          so i must pay for the upgrade?
                          850 power suply
                          Windows 10 Pro
                            Are you sure your dongle is not upgrade to 2.0 already? And where do you buy VisTitle from? I think there are not 1.x stocks in internaltional market.
                            We have free upgrade policy, please reference http://www.vistitle.com/listNews.asp?ID=19.
                            Please send us your purchase invoice, we will give your 2.0 activation code if your dongle meet requirements of free upgrade.
                              Hi chen i email you the serial number plus the invoice i bought it at bh store on 34 st i am waiting for the serial number for the 2.0
                              not sure why it taking so long can you check your email please i want to get started on a project with the titler thanks .
                              850 power suply
                              Windows 10 Pro
