Vistitle 2 upgrade?
  • Vistitle 2 upgrade?
    Has anyone been able to order and receive a Vistitle 2 upgrade from version 1?
    I have tried several GV resellers who don't have supplies , and have even sent a PM to VXchen, but again no reply.
    If there is a delay, does anyone have a date when this might be available?
    John ,
    Ive been waiting for a week for a 1.8 to 2.0 upgrade license. Hopefully i get one soon.
    Chris
    Proud user of EDIUS!
      I can only tell that the free upgrade from 1.x to 2.0 took less than 24 hours from sending the mail to receiving the serial.
        No promblems here, had it downloaded, serial emailed to me, installed all in 24 hrs.
        Mark
        Mark Twittey
        Walkabout TV
        Edit 1: Custom Built 3XS System, Dual Boot WinXP Pro 32bit/ Win7 Pro 64-bit,
        Asus P6T Deluxe Motherboard, Intel I7 2.66GHz CPU, Nvida GeForce GTX 580 card, LSI Raid controller,
        5Tb WD drives, 12Gb DDR3 Corsair memory, 2 x 27" ASUS LED's, Edius 7.4 & Liquid XE, Boris RED 5.4.0.378, Vistitle 2.5. New Blue Video Est.III
          The question is for people who don't get a free upgrade.
            have you heard from GV Australia to see if and when users will be able to buy it?
              I have just received a PM from VXchen (he is at BIRTV 2012) saying that it is down to GV, in Europe in my case, to finalise the process for the upgrade path.
              Come on GV it can't be that complicated can it?
                Anton. As per John's comment. And they are at Integrate
                  Just been informed that Sharbor.com are good to go allow 24hrs for delivery (licence)
                    I have a problem with the Vistitle2.0-Upgrade. I have purchased a "VisTitle 2 (Upgrade from 1.x) with Plug-In Pack" and I have received a new serial number from the reseller. I have downloaded the Vistitle2-Fullinstaller.
                    During the installation of Vistitle 2.0, I am prompted to plug in the USB-dongle from 1.x. Without the dongle, the installation will not continued. When I plug the dongle, the installation continues. There is no request to input the new serial number. Vistitle 2.0 works fine. However, the paid-plugins "2D-to-3D" and "3D-Charts" are not enabled. Vistitle 2.0 has the old serial number from 1.x and not the new serialnumber. The paid-plugins can not be activated with the new serial number.
                    Does anyone have any advice?
                    Regards
                    wihe
                    MB: GA-X99 UD5 WiFi, CPU: i7-5930K, RAM 32GB DDR-4, nvidia geforce gtx980, Intensity pro 4k, Win10pro, Edius 9.10WG
                      Did you uninstall the previous verrsion first ?
                        I have now received from the reseller the five activation codes for every five paid plugins. Was probably just an oversight.
                        Vistitle 2.0 now works fine with all Plugins.
                        Regards
                        wihe
                          thats great news!! i hope mine get activated as well.
                            Regards
                            wihe
                            I haven't found a reseller with the upgrade to buy. Can you let me know where you had success?
                              I have purchased VT2 from sharbor.com
                              Regards
                              wihe
