BorisRED 5.22 ready for EDIUS 6.5
  • BorisRED 5.22 ready for EDIUS 6.5
    RED v5.2.2 - Adobe CS6, Edius 6.5 support added
    Graffiti v6.0.5 Update - Adobe CS6, Edius 6.5 support added
    BorisFX 10 Plug-In is not pblished yet
    http://www.borisfx.com/updates/#null
    Eric
    English is not my native language
    ___________________________________
    System 1:Intel core i7-6700K 4 GHz - ASUS Z170-A - 32 GB DDR4 RAM - Intel HD 530 Graphic - Win 10 Pro - Storm 3G - Blu-Ray LG BH10LS30
    System 2: Intel i7-960 3,2 GHz - ASUS P6T - 12 GB DDR3 RAM - Radeon HD 5850 1GB - Win7 Ult 64bit SP1 - Storm 3G - Blu-Ray LG BH08LS20 - LG GH22NS50
    Hi Eric i cant see it for 6.5 the options for 5.2 are: Red Installers have no 6.5 options, with Cs5.X and CS6 no mention of Edius. With Edius option it offers CS3 and 4
      Download the 5.2 for Edius 6 32 Bit. It is actually the 5.22 updater even though it doesn't say it.
      Tom Koveleskie - Director/Producer/Editor
      Quarter Town Films - Independent Feature and Documentary Films.
      Edius 8 WG with HDSpark, AMD 8 core FX 8370 Black Edition 4.3 GHZ, MSI 970A Krait Edition, 16 GB Patriot DDR3 1333 MHz RAM, EVGA Nvidia GTX 780 TI graphics, Win 10 X64.
        John, I have installed the full 32bit version (trial download), not the update.
        Update doesn't seem to be actual
        My RED version shows 5.22 and it is available as plug-in on EDIUS 6.5
        During installation, I missed an option CS5/6, witch I don't need.
        Eric
          Thanks Eric likewise im running in trial mode at present. I have contacted Boris because of problems after Edius 3d Demo/trial had to complete deep format HD this is a clean install so my previous Activation code doesnt work but so far it runs and outputs to HDStorm but havent tried anything else yet
          red usually gives you the full trial and picks up your details which are not on my PC
          I had no options offered for that one as none of the CS or Vegas 32bit are on I will have to DL the 64bit version for those
            John, now I got it --> CS6 is 64 bit only. That's the reason for not showing up on the 32bit version
            Eric
              Excellent response from Mukesh at Boris with an answer to my registration problem
                Hi gents,
                I just installed trials of Boris RED 5.2.2 and Boris FX 10.0.3 under Edius 6.07. Pity to say both plugs crash Edius when applied on clip and open. Any experience and suggestions?
                BTW, what was the answer re activation problem w/ Boris RED - I've heard a couple of times about the issue?
                Workstation: Dell Precision T5500 | Edius NX HD Suite w/ Bay | OS: Win7 Ultimate x64 | CPU: Two Intel Xeon X5550 2.66GHz | 48GB 1133MHz DDR3 ECC-UDIMM | Boot/Apps Drive: WD5002ABYS 7200RPM | Video: 2x500GB Raid 0 (1.0TB) | Graphics Card: NVIDIA® Quadro® FX 3800 | UAD-1 | TC Electronic PowerCore Express
                  I would disable open GL overlay in all Boris products
                    I reported the crash problem to Boris a few weeks ago, go back to 5.13
                    If you have problems re acticvating send email to customer support at Boris, they were very helpfull
                    Did you install/change any components.
                      I completely reinstalled my workstation from the ground. Thus, my Edius 6.07 and both Boris' trials are quite a fresh. Seems this is compatibiliy issue which might be fixed at forthcoming releases of Edius or Boris. Hope, Boris' staff is aware about the issue.
