iZotope for Edius 6.5
  • iZotope for Edius 6.5
    I've installed from the older Edius6.07 the iZotope plugin.
    You can find this folder Edius 6 / Plugin / VST
    Put this folder in the VST-Plug-In-Brige. and you have again all the iZotope filters back again!!
    It functions fine, no problem up to now.
    Dirk PEL(NL)
    Or copy the contents into the EDIUS 6.5 VST folder. If you don't have them installed at all you can still install them from the version 6 bonus disc. Once installed they are in a stienberg folder (under programs files (x86)- close to the Grass Valley folder)rather than the correct EDIUS folder, so find them and copy them from the Stienberg folder into the EDIUS 6.5 VST folder.
