release Edius Macro Generator 5.1
  • release Edius Macro Generator 5.1
    Dear Members,
    After the great success of version 4 of Edius Macro Generator, I can inform you
    that a new version of
    EMG-Edius-Macro-Generator 5.1 is now
    available for download.
    Until 1° August the cost is only 13,99 €
    At the end of this topic you will find a list of all the new features and
    tutorials. We tried to make its use, intuitive and as simple as possible
    Download the full version will always be available here: http://www.ediusmacrogenerator.net/S.../Emg5_full.exe
    Download updates will always be available here :…http://www.ediusmacrogenerator.net/S...mg5_update.exe
    A setup file for the proper function of Edius keyboard with EMG-PRO v 5.1 can
    be downloaded here: http://www.ediusmacrogenerator.net/S...e/keyboard.zip
    The following article lists the most important news and invites you to look at
    the various tutorials:
    - Improved application engine of the macro-building-tool, making it more
    efficient and safer
    - Developed a system for visual and simplified management of the macro
    - Now you can export now from Edius, Chapters and Subtitles to Adobe Encore
    - Now you can export Chapters to DVD Lab Pro
    - Improved the vocal Commander System
    - Macros are divided by folders, you can create countless and endless folders
    and Macros
    - Each folder can be customized to your liking and completely independent of
    each other
    - Added a favorites folder # in which you can quickly call up the macro
    referred by you as "favorite"
    - Add a Folder “Click Top” to go, where you automatically organize your macros.
    Just click at one
    to recall it.
    - Improved the multimedia player, Which you can now send and listen to the Bin
    folder of Edius,
    using
    drag and drop or by using the "Add To Bin" to send one or more
    multimedia files
    - Created a new interface for inserting macros quickly and intuitively
    - The windows of EMG can now also be dynamic,
    This means that you can reduce the space of the
    windows of EMG, in this mode the windows open when the mouse passes over the
    windows and close when not in use Emg- Infinite Manage-Layout, as in Edius,
    EMG now has the ability to manage its layout, so you can have multiple
    configurations of graph layout, and so it is possible to associate a layout
    with a Emg- Edius layout. When you change the layout of EMG it also changes the Edius-layout
    - The effect manager was further enhanced with
    graphics and effective application of effects and transitions, you can now
    customize the application parameters directly from the effects of Effect
    managers were, therefore, created the new features and Duration Duration IN OUT
    applicable to all transitions in the track mixer, Emg system in practice the
    transition in the channel mixer to fit The appropriate duration of overlap of
    the two clips
    - control of the keyboard has been enhanced, so now you can assign each macro a
    keyboard key,
    and then apply the macro with any
    combination of keys
    - Added a legend to a memorandum of keys you want to have always available for
    macros, and
    G15 keyboard for idkey
    - Improved slide show, after placing the clips in the timeline, it is now
    possible to determine the
    duration, transitions, filters and picture and
    picture to be applied to clips.
    - Redesigned off-line project management, now it's really simple to speed up your
    off-line projects
    - Created a new project system offline by bin, you can now take the clips from
    the bin and put directly into projects off-line
    - Created the opportunity to share projects between
    users off-line, wants to create a part Which is
    accessible to all users, Which Will
    Provide at least two projects off-line use with Edius feature
    projects off-line macro generator edius 5
    - Improved Clip-on marker Cut to cut the clip where
    the markers are on timeline
    - Improve the export codec functions to automatically export all the clips from
    the timeline in the current format or codec to default
    - Improvements to make clip in the timeline, to put down a marker to each clip
    on the timeline
    - Macro system, adding the ability to create macro EMG system, ie, all system
    functions may be associated with Emg Considerable macro keys as actual
    - Management tutorial, adding management tutorial, is now present on every
    screen a link to the video tutorials on “You tube” and link to a discussion
    forum where you can write your thoughts
    First of all, thanks to all those, who supported me in bringing this project
    forward and that they consider it essential for anyone using Edius.
    For those who have already made a donation, for the upgrade to version 4 to 5 it
    requires only a donation of EUR 9.99 to get v.5.1
    For those who never have made any donation, to get the EMG version 5, a
    donation of 13.99 Euros is required
    For those who want to use the Free version of EMG. completely free software,
    without time limits, will have to accept some limits
    of available functions and macros created.
    This Edius Macro Generator 5 is a keeper and Remember "With Edius Macro
    Generator, Edius, puts Wings !"
    Developer of Macro Generator Pro for EDIUS
    http://www.macrogenerator.net
