chapter points dont work in labpro
  • chapter points dont work in labpro
    Hi everyone.Till yesterday i had no problem exporting chapter points and load them into labpro.I just finished a multicam project.i made my chapters.export them as always, but when i import them in labpro , from 25 markers,it puts the first 10(inwrong position) and the others it syas that it can not put them cause maybe its out of time.But in edius everything is between IN & OUT in.
    Any advise?
    I5 4690 CPU
    MOTHERBORAD GIGABYTE GA-Z97-HD3
    RAM 8GB [email protected]
    AMD RADEON HD 6800
    2X2TB WD CAVIAR BLACK (RAID 1)
    2X2TB WD CAVIAR GREEN (BACKUP)
    1 OCZ SSD 128GB
    Windows 7
    Edius 9&8 Workgroup
    Any advise?
    did you export the chapters with the free marker exporter plugin from Germany? always works perfect for me
      Yes Anton.I use it all the time.But now it has an issue.
      Is there a chance that the problem is cause i export the markers from a multicam? As i said everything is between in&out in Edius.Its a project with 25 chapters and because its a dance show it is not so easy to manually put them cause i have to search frame by frame.any idea why ths happend to lab pro?
      I5 4690 CPU
      AMD RADEON HD 6800
      1 OCZ SSD 128GB
      Windows 7
      Edius 9&8 Workgroup
        ok...the funny part...
        I worked in 2 seq. the first sequence goes for the first dvd and the second.....for the second.
        so..i export the second sequence markers and...IT IS WORKING in labpro.
        So i think i'm loosing my mind.smae project just different sequence. all markers between in&out.
        first seq (dont work-it says out of length)
        secong seq (Work)
        I think i will go crazy :-)
        I5 4690 CPU
        AMD RADEON HD 6800
        1 OCZ SSD 128GB
        Windows 7
        Edius 9&8 Workgroup
          what says: out of length? DVD-Lab or EDIUS
          can you paste the marker exporter text into your next reply
            I uploaded hte chapter export.Is something wrong with it?
            Labpro during the loading chapters says that from 119117 marker that the rest might be out of length.
            Any help?
            I5 4690 CPU
            AMD RADEON HD 6800
            1 OCZ SSD 128GB
            Windows 7
            Edius 9&8 Workgroup
              Any help?
              you have your marker exporter set incorrectly
              for DVD Lab it needs to be set to SMPTE and not Frame
                Till yesterday I used to export in frame and not in SMPTE and everything was ok.I tried today with SMPTE and again it didnt work.It starts wrong from the beggining.it places the first chapter almost 8 min later than normal.I tried to put them manually and again nothing is working.In the second dvd everything works perfect.I will try to make a new project starting from new export from edius till the end to see if it will be ok.
                Thanks for the help
                George
                I5 4690 CPU
                AMD RADEON HD 6800
                1 OCZ SSD 128GB
                Windows 7
                Edius 9&8 Workgroup
                  Thanks for the help
                  George
                  are you sure your footage starts at 0 timecode on the timeline? the inpoint must be at the very beginning
                  marker exporter starts counting from the beginning of timeline and not from in point in case the inpoint is 8min later
                    you are right.My in point was not in the very beginning.But the strange thing is that my second sequence was also like this and also i exported in frame ( not in Smpte) and it worked.
                    but i tried my in point from the very beginniing as you said and everyting was fine.
                    Thank you Anton
                    Appreciate it!
                    I5 4690 CPU
                    AMD RADEON HD 6800
                    1 OCZ SSD 128GB
                    Windows 7
                    Edius 9&8 Workgroup
                      basically, my in point is always at very start and the footage starts 1 sec later with a fade in
