Edius 6: to use Magic Bullet without After Effects?
  • Edius 6: to use Magic Bullet without After Effects?
    Hi, I use Edius 6 and I'd like to know if it is possible to use Magic Bullet Looks without installing After Effects CS4 x32.
    CPU: Intel i9 7940X
    SSD Drive:
    32-bit version of Looks 2 works fine via EDIUS6 AE Bridge.
    You don't need AE.
    Eric
    English is not my native language
    ___________________________________
    System 1:Intel core i7-6700K 4 GHz - ASUS Z170-A - 32 GB DDR4 RAM - Intel HD 530 Graphic - Win 10 Pro - Storm 3G - Blu-Ray LG BH10LS30
    System 2: Intel i7-960 3,2 GHz - ASUS P6T - 12 GB DDR3 RAM - Radeon HD 5850 1GB - Win7 Ult 64bit SP1 - Storm 3G - Blu-Ray LG BH08LS20 - LG GH22NS50
      This is correct. The installer wil create an Adobe folder.
      I that folder you will see an Adobe affter effect CS3 or CS4 folder and a Common folder.
      The Redgiant plun-ins reside in the common/plug-ins/CS3/Mediacore folder. CS3 can be replaced by CS4 depending on the install fyi.
        You don't need AE.
        Eric
        Confirm, we use MB-Looks everytime via AE-Bridge. Works great and very stable. You can also use the presets, because it comes up with the MB-Mask.
        ciao
        Werner
        Werner Weißböck
        [SIZE="2"]X-trem production, Austria
          Want to start learning to grade and looking at MB Looks 2. Is it still stable in Edius 6?
          Motion Art Cinematography
          Windows 10 Home 64 bit, Intel I7 4.2ghz, 32GB Ram, Nvidia GeForce GTX 1070
          Gold Coast, Australia
            It's very fine - no problems - generally not real-time - but depends on your system.
            For a better grading tool, use Da Vinci Resolve Light - free. Does not plug into Edius.
            Paul :-)
              install it for vegas and export...
                I have installed Magic Bullet Suite 11.4.2 32-bit but I don't see that folder. The plugins folder is empty. May be is it a wrong version? What version of Magic Bullet Suite do you use please?
                CPU: Intel i9 7940X
                SSD Drive:
                  search for .aex
                  see if you see looks in the list
                  Remember looks.aex is the correct one for 6.5 and lower
                  Looks64 is the right one for EDIUS 7.xxx
                  Also the suite contains plugs which are not compatible with EDIUS.
                    search for .aex
                    In my hard drive I don't have any looks.aex file. If my Magic Bullet Suite 11.4.2 32-bit contains plugs which are not compatible with EDIUS, which Magic Bullet have I use precisely please?
                    CPU: Intel i9 7940X
                    SSD Drive:
                      Sorry if you don't see the .aex you have not installed the plugins correctly or you should enable show hidden files and folders.
                      For correct installation information please consult the readme or the support faq of Redgiant.
                      This page will be very helpfull:
                      http://www.redgiant.com/support/faq/...let-looks/340/
                      Looks is compatible but there are other plug-ins in the suite which are not compatible.
                        I have just installed another version of Magic Bullet and now it works fine. Thanks
                        CPU: Intel i9 7940X
                        SSD Drive:
