Vistitle 1.8.5
  • Vistitle 1.8.5
    There is a newer version of Vistitle, version 1.8.5 here:
    Several new features and many bug fixes
    Yeah,
    formatted Subrip files are now interpreted correctly!
    No need for manual correction anymore!
    This is a huge timesaver for me!
    I archived that before by splitting subtitle files in three parts:
    - 1st file contained all subtitle spottings without format tags
    - 2nd file contained all partial formatted (single words or phrases) subtitle spottings (manual formatting in subtitle editor)
    - 3rd file contained all full formatted subtitle spottings
    All subtitle tracks has been layed in the timeline!
    Can you put some references related to SRT format tags in the manual to take care that tags are archived for export to SRT file?
    With this information film makers would be able to set the right format tags from start now!
    Thank you so much!
    It really works like a charme!
    Cheers
    Andreas Gumm
    post production / authoring
    Windows 7 Ultimate,
    GV hardware: 3G Storm
    PC 2
    GV hardware: HD SPARK
      I'm VERY pleased to report that my problems with crashing seem to have been eliminated.
      2950X 32GB Win10, Gigabyte GTX 970 (IXOC), dual EA275UHD, QNAP 873 (w/10GbE). Video source typically HC-X1 or Panny TM700; Audio DR-701D and Rode NT4. Edius 8.5 WG w/ Vistitle & TmpGenC.
        Same here, works like a charm.
          EDIUS 6 Crash Freeze w/ VisTitle 1.8
          I hope you are right - cuz I have had nothing but problems since VisTitle 1.8 was installed. Strange lockups and crashes for no apparent reason.....
          I will be putting the system to the test using VisTitle 1.85 later today.....
            If you still have this issue after you install 1.85 can you send me a PM?
              I installed 1.85 and it works fine. My 1.8 worked fine as well.
                In my case I have gone from a reasonably stable version 1.8.0 to a new version 1.8.5 that crashes every time. It won't edit an existing title, and it cannot create a new one, even in a blank project. As soon as I try to add any sort of object (text, image or rectangle) it crashes. As soon as I hit the Edius tab it crashes.
                This does appear to be Edius related. The standalone version, which I never use, seems to be OK.
                I am having to regress to the old version.
                Andrew
                Andrew Pinder
                www.chpv.co.uk
                  OK reverted to 1.8.0 then tried again. Didn't do anything different, but now VisTitle 1.8.5 works perfectly. Go figure!
                  Andrew Pinder
                  www.chpv.co.uk
                    could have been caused by antivirus software if enabled or windows defender if enabled
                    antivirus software is the biggest virus in itself when it comes to EDIUS
                      Vistitle 1.8.5 update
                      I recently purchased Vistitle 1.8.0 and it installed and ran fine.
                      Installing the update to 1.8.5 today ran OK, when but running Vistitle via Edius 6 VT would crash as soon as I tried to do anything, like create a title.
                      Following Anton's comment about antivirus, I uninstalled Vistitle, and turned off antivirus in BitDefender, reinstalled VT 1.8.0 then 1.8.5. Rebooted and turned AV back on, and so far Edius and Vistitle are running OK. I even managed to install Edius 6.07 using the same process.
                      As my system is not used just for video edits I always have a good AV and firewall program running.
                      PS - I had not been able to access the Vistitle website since purchasing VT a week ago. Kept getting ERROR PAGE. If any one else has this problem, use this IP address to get to the VT web page - http://96.0.234.168/
                      Cheers,
                      Max
                      EDIUS Pro 9.5, VisTitle 2.5, Windows 10 Pro 64-bit, dual boot - normal desktop & Edius. i7 6700K O/C at 4GHz, 16Gb Corsair DDR3, MSI Z170A M/B, Corsair H50 liquid cooler. nVidia GTX1660 6GB, 2 SSDs, 2 WD 7200rpm HDDs, 2 x 24" monitors. ShuttlePro 2. Panasonic Lumix GH4 camera
                        Cheers,
                        Max
                        I check www.vistitle.com in here, it is ok. Is there any one has this problem too?
                          Either www.vistitle.com or http://96.0.234.168/ works fine from Malaysia.
                          Tony D.
                            I can't open with IE only with Firefox.
                            I'm going to reload 1.85 today. I loaded in Friday, but Vistitler now crashes when I open it in Edius.
                            tdtinker
                            tdtinker
                            Edius 8.5
                            www.actvp.com
                              Did a complete uninstall of vistitler and reinstalled, no crashes on.
                              tdtinker
                              tdtinker
                              Edius 8.5
                              www.actvp.com
