BCC Filters
  • BCC Filters
    G'day Guys
    In my Video filters folder I have "After effects Plug-in" folder.
    When I try to use them I get the effect but with a watermark from Boris.com at the top (it's upside down and back to front!)
    I have boris red 5.0 installed.
    What do I have to do to use the filters?
    Mark
    Mark Twittey
    Walkabout TV
    Edit 1: Custom Built 3XS System, Dual Boot WinXP Pro 32bit/ Win7 Pro 64-bit,
    Asus P6T Deluxe Motherboard, Intel I7 2.66GHz CPU, Nvida GeForce GTX 580 card, LSI Raid controller,
    5Tb WD drives, 12Gb DDR3 Corsair memory, 2 x 27" ASUS LED's, Edius 7.4 & Liquid XE, Boris RED 5.4.0.378, Vistitle 2.5. New Blue Video Est.III
    For Boris RED5 you can just drag it to a clip... you will find it in your filters and transitions folders if indeed you installed it into Edius correctly. You do not need the Bridge.. RED5 is a plu-in for Edius and so works directly inside the program.
    Best
    Dave.
    www.nakedeyedv.com
      G'day Dave
      Thanks I know I can use Red, I have been doing so ( I should have said)
      What are the BCC effects in the After effects folder?
      Mark
      Mark Twittey
      Walkabout TV
        Does anybody have the same folder structure as I do?
        I still do not know why I have the BCC filters in my after effects folder.
        do they go in without Boris in Edius?
        Mark
        Mark Twittey
        Walkabout TV
          when you installed RED, the default is set to custom, where you can select and deselect plugin locations
          I only selected EDIUS, because I don't have AE :)
            Thanks Anton
            Thats what I must have done.
            I have version of After effects I might put it in
            Mark
            Mark Twittey
            Walkabout TV
