Vistitler Question number 36
  • Vistitler Question number 36
    How do you apply a border around a photo in vistiler?
    tdtinker
    tdtinker
    Edius 8.5
    www.actvp.com
    The way I do it
    Draw the box for the picture
    Select Use shader style to render
    select Always use Image Color as Face color.
    Then I add frame in custom Styles
    The I choose the picture and adjust the frame to my liking.
    This is the method I ue because I can choose Texture, sheen and such.
    I can make it ugly if I want. :D
    (I know some will say technically it is not a border. )
      Thanks, that what we did, but was hoping for an easier way, like add outline.
      tdtinker
      tdtinker
      Edius 8.5
      www.actvp.com
        tdtinker
        that is what I do, I add outline and drop shadow and set blur etc.
        as long as Select Use shader style to render is ticked, all the usual options will work
        then when you add another image, it will automatically apply the same edging as long as Use shader style to render is ticked
          That also works ....
