Blue FX Trail Problem
  • Blue FX Trail Problem
    Decided to try Blue Fx Title Pro trial and did not care for it. I then uninstalled it but the option to select as Title option still shows in Edius 6. Uninstalled entire Edius installation along with 3rd party software. reinstalled and still Blue FX title pro shows up. Can anyone tell me whats is going on with Blue FX that it wont uninstall itself? Thanks.
    I apologize that you're having trouble with our software. Just to clarify, after uninstalling Titler Pro, you are still seeing a "NewBlue Titler Pro Importer" option when you press the text button in Edius? Do you also see that option if you right click in your project bin and look under "New Clip"?
      I had a play with NewBluetitler in an Edius project
      I had a similar problem after uninstalling the NewBlue titler.
      I had to install it again but once I'm finished with this Edius project I'll uninstall titler pro again.
      Tony
        I'm very sorry guys; this isn't something that we ran into during testing.
        Perhaps the Titler Pro plugin file is not being removed from the Edius plugin directory? I can give you instructions on how to remove this file manually, if need be.
          That is correct, when I press the text button in Edius I still see the option for Title Pro. Update: in reading other post I went to windows explorer and started looking into the Edius folders and sub-folders. I found the folder for plugins and found a Title Pro entry and deleted it. I also deleted the the Title Pro folder in the root Windows directory. This took care of the opertunity for me. I would say that the un-install routine is not capturing eveything that gets put in. THanks for the help.
            Thanks, I'll have a look.
            Tony
              Yes, I guess the uninstaller wasn't able to remove that file for some reason. If you don't mind me asking, what version of Windows are you using?
                Win7 Ultimate here.
                Tony
                  Windows Vista64
