Best titler for edius
  • Best titler for edius
    What's the consensus on the best titler software for edius 6?
    I've heard of Vistitler but have not tried it.
    Does NewBlue have anything?
    Any other possibilities I may not be aware of?
    Thanks,
    Bill
    You could check the web pages download the demos so you can judge which one would fit your needs.
    Titlers:
    Vistitle
    Heroglyph
    NewBlue Titler pro
    RED
      Bill, what works for me may or may not work the same
      for you. As Steve said download the trials and give them a whirl.
        Thanks,
        Bill
        Hi Bill, we just released the Edius compatible version of our NewBlue Titler Pro software. If you would like to try it yourself, you can download a trial version here:
        http://www.newbluefx.com/downloads/W...owsSetup10.exe
          I gave NewBlue a test run....verdict.....Love it....easy, simple, clean type, and it plus in to Edius without any hiccups on my end......Think I will purchase this.....was also viewing some tutorials on YouTube....very straight foward and easy to follow....but then again, I usually try out things for myself....
            What I really need is lower thirds templates. I don't see any in Titler Pro.
