Titler - Edius Beta!
We are pleased to announce the Edius version of Titler Pro is now available for testing. Your feedback is very important to us and can help shape the usability and features of this product and we certainly wish to hear your comments on what's good, what's bad, what could be improved, and other features you would like to see. So please give it a test and let is know your thoughts.
Please download and test with this new version and, once again, please return your feedback to us. The NewBlue Titler beta may be downloaded here:
Feature Areas
Here are some feature areas to go through as you explore Titler Pro:
Manipulating text in both paragraphs (strings of characters as one block) and as individual characters.
Navigating the Library
Applying styles and making your own with Style layers
Applying transitions and effects to paragraphs (there are also “Animation” categories in each)
Adding shapes in paragraphs, or as stand-alone and applying Styles to them
Applying effects to individual Style layers (can only be applied to 2D layers)
Keyframing paragraph position/rotation/scale and effects on paragraphs
Let Us Know
As you explore, please make a note of:
What you find as strengths, or what you’re impressed by
What you find as difficult to understand or use
Any moments where you believe they are a bug
Any performance or stability issues
What key features you believe are missing which severely limit your ability to use Titler Pro as your “go-to” tool for titling (we’re already loading the hopper with next-gen feature ideas)
Known issues:
As we add additional NLEs, we do have some know issues that are still being worked on. So if any of these apply to your testing, we already know about these issues:
Edius:
Duration of your Titler clip can only be changed when you first create a new clip. When you create a new Titler clip, there will be a "Duration" box in the upper right corner of the Titler interface. Enter the duration that you want that Titler clip to be. Once you save your clip, the duration will remain fixed even if you edit it.
If you have a Titler clip that is longer than 10 seconds on your Edius timeline, when you edit and re-save the clip, occasionally the duration will be shortened to 10 seconds. We are working to resolve this issue:
As a workaround, to get your clip back to its original length, reopen it by double-clicking on the clip, make a small change, then select the "Save as New" option. This will place a copy of the clip in the Edius bin at its original length.
Reporting Comments or Bugs:
Please include the following information when reporting bugs or other notes you believe we need to consider:
To: Edward Troxel ([email protected] ),
Marcus Johnson ([email protected])
Subject: NewBlue Titler Bug Report : <a brief description >
Message:
· Name, version and operating system of the video editing software you are using.
· Steps needed to reproduce the problem.
· Optional: Include screen shots
Naturally, we may request more information as needed.
Again, thank you so much for participating with us to make Titler Pro the best it can be. We deeply value your feedback, so please communicate with us often.
Sincerely,
The NewBlue Team
NewBlue, Inc. is more than a plugin maker. We enable video enthusiasts and professionals alike to customize media and stand out in a crowd. Follow NewBlueFX
Our goal is simple: To be competitively-priced, aesthetically fresh, and ridiculously easy to use. At NewBlue, we love technology. But more importantly, we adore the arts. On our team, you'll find musicians, filmmakers, artists and writers, all brought together by the desire to merge our passion for the creative with our talent for the technical. Our line of NewBlueFX plugins demonstrate this arts and technology merger and so will each of our products to come.
You're receiving this newsletter because
you're a legendary NewBlue customer,
or subscribed via our site.
Unsubscribe instantly.
4225 Executive Square, Suite 480
La Jolla
Feature Areas
Let Us Know
Known issues:
Edius:
Message:
Sincerely,
The NewBlue Team
La Jolla
