Isotope and crashes
  • Isotope and crashes
    I have long avoided adding vst filters after reading the various problems over the years. this week i added them to my XP workstation and applied the audio restore which does a remarkable job of cleaning up some hiss on interviews, but now the timeline seems unstable, and shuts down in the middle of playback, or sometimes when scrubbing. Simply stops. And since Edius is not responding i must restart,
    I hate to lose the audio restore function but can't work this way. before i trash them all, thought i'd ask if anyone else has this problem and has it solved...Perhaps i should uninstall all isotope vst filters except the audio restore filter?
    Hudson Valley, NY
    i7 8700K @ 3.70 Ghz/16 gb RAM
    windows 10
    284 gb SSD boot drive
    2 TB work disc
    2TB storage disc
    EDIUS 9.52.6031
    can you describe the audio file properties?
    also, what is the min and max size of the pagefile.sys and which drive is it on?
    I had strange problems with certain plugins when I had the pagefile disabled at one stage, so now I set 2GB as min and max on my C: SSD drive and all is well
      the audio files are standard .wav files.
      I guess I don't know how to see the pagefile info you mentioned, nor how to reset it...
      I am going to start by removing all vst files except the audio restore.
      The timeline just stops-hangs---The Task Manager reports "not responding"...It just happened again after rebooting and making (and saving) 5 timeline changes. Unfortunately this is a large project and takes a bothersome amount of time to reboot.
      Yesterday it hung up while outputting to an HQ file for backup.
      Hudson Valley, NY
      windows 10
      2 TB work disc
      2TB storage disc
      EDIUS 9.52.6031
        to set pagefile, right click computer, properties....
        http://www.videoproductions.com.au/edius6/pagefile.png
          thanks, Anton...I made the change..will see what happens...
          Hudson Valley, NY
          windows 10
          2 TB work disc
          2TB storage disc
          EDIUS 9.52.6031
            unfortunately, no change. still hanging and non responsive.
            will try again tomorrow.
            Hudson Valley, NY
            windows 10
            2 TB work disc
            2TB storage disc
            EDIUS 9.52.6031
              are there errors in event viewer, applications, as to the cause of the EDIUS crash?
              how did you install izotope, was it from EDIUS6 Bonus DVD?
                Yes, Anton, I installed the izotopes from the Edius 6 bonus disc. i uninstalled them and reinstalled. i'll check the event viewer tomorrow if (when) i get a chance to edit and have a hang up.
                thanks for continuing to help.
                Hudson Valley, NY
                windows 10
                2 TB work disc
                2TB storage disc
                EDIUS 9.52.6031
                  I managed to get some edits done without crashing..saved OK...Tried to output to an HQ file..hung after 31% completed. No messages in the event viewer after stopping the process ...would it make sense to try and put the page file back to recommended values? or to zero? Or would upgrading to 6.05 make any difference...I prefer updates after projects are completed...but...
                  Any help greatly appreciated...I hate the thought of removing all the audio restore filters...I put them in on many, many clips that had some background hiss...and used automatic setting, which, as I said, did a great job cleaning up problem areas...Is there an alternative to this filter I might try?
                  Hudson Valley, NY
                  windows 10
                  2 TB work disc
                  2TB storage disc
                  EDIUS 9.52.6031
                    Can you try the following?
                    Put in / out over the time line press Shift +Q.
                    After it is complete
                    Export to HQ.
                    Does it work?
                      Because of the nature of the edit I have been rendering segments throughout the 40 min piece. So, everything has A Shift Q render on it. Not able to output n HQ and I was unable to burn a DVD from disc-burner either. It stopped at 62% encode...looks like i should remove the audio restore effect from any clips and start rebuilding the sound without this. Any reliable tool to replace this with?
                      What does "page filing" effect and where should it be normally set for Edius to function well?
                      Hudson Valley, NY
                      windows 10
                      2 TB work disc
                      2TB storage disc
                      EDIUS 9.52.6031
                        Just do a new one..shift + Q render. Again put an in and out over the entire timeline and do a shift + Q render.
                          Try deviding the main timeline in smaller sequence chunks, don't delete the main sequence, just copy n paste and try to render the smaller sequences.
                          You might be able to render all and paste to a new main sequence, or at worst case find the offending clip(s).
                          Tony D.
                            i currently have six sequences on the edit...each small groups clip has been rendered within the sequence. I don't see why rendering would effect this is the audio filter is to blame...
                            I've removed the effect and will see how well it plays without audio restore in use.
                            Hudson Valley, NY
                            windows 10
                            2 TB work disc
                            2TB storage disc
                            EDIUS 9.52.6031
                              which version EDIUS do you have now? it shows6.05 in your signature but you asked if upgrading to 6.05 would help
                              EDIUS6.0, 6.01 and 6.02 were bad
                              you don't need to delete izotope, just untick in info palette and see if it exports then
