Vistitler has slowed down system
  • Vistitler has slowed down system
    We are experienceing a problem with version 1.8 slowing down are system.
    Any suggestions?
    tdtinker
    tdtinker
    Edius 8.5
    www.actvp.com
    Nobody experiencing this problem?
    tdtinker
    Edius 8.5
    www.actvp.com
      Vistitler has slowed every down so much I'm going to go back to TMP for this project. It is ridiculous how slow it has become. It even stops play back on the timeline. If I make the same title in TMP it plays fine.
      tdtinker
      tdtinker
      Edius 8.5
      www.actvp.com
        Fine here.
          Would it make any difference if we are using a external drive?
          tdtinker
          Edius 8.5
          www.actvp.com
            tdtinker
            Can you send me some your title files (*.vtlayout) which slow down your timeline, and let me looking into this issues. And, I guess, these titles should be animation titles, right ?
            In most situations, VisTitle layout should be played with realtime.
            As I known, when we create a TMP animiation titles, before return to EDIUS, it was rendered to a disk files, so it was always realtime play in timeline. But, you have to wait them to rendered.
              I'll send them to you later, the are simple stills. White text place above video track.
              When I made the same title in TMP Edius played fine. Maybe the files got corrupted?
              tdtinker
              Edius 8.5
              www.actvp.com
                it could be that the EDIUS buffer is set to high
                when I set mine to 512, EDIUS often runs out of memory due to the incorporated Vistitle memory consumption, no problem when using 128 buffer
                this has been confirmed by VX Chen and he said this problem should be gone with 64bit version of EDIUS and Vistitle
                  Problem solved bt Vistitler. I sent one of the titles to vistitler and they send me this back. "Yes, “Best of the Best.vtlayout”clip is very slow, its outline shade property had checked“Concave” and “Bevel”property, and set some large unnecessary blur size. From the render result, I think you can uncheck these property, and set the outline color to RGB(54, 16, 15) directly. "
                  Thank you Vistitler
                  tdtinker
                  tdtinker
                  Edius 8.5
                  www.actvp.com
