I've searched the forums and see that others have had this problem, but I do not see a difinitive solution. I've also been in contact with George Dame, who sold me VisTitle, but he has not been able to help so far.
The problem is that the VisTitle dongle drops out of the system at random. When in Edius, I get an error message "E0003: VisTitle Key is not attached or is defective." and Edius crashes. When launching Edius, if he dongle is not illuminated, I get a the same message, but I can continue without the VisTitle plug-in by "cancelling" the error dialog.
I'm using Edius 5.51 and VisTitle 1.5.3.0 . The system OS is Vista (32bit) Ultimate, SP2, and I think all updates are current. I normally use a multi-port hub for my dongles (Edius and ProCoder3 constantly, and a couple others as needed). I've tried plugging the VisTitle directly into the motherboard USB ports, and I've even tried attaching the "optional" external power supply into the hub (to eliminate the possibility of a power overload with three dongles). And yes, I've even tried different hubs. And finally, I've tried plugging the VisTitle dongle in all the way and only part way, just in case there's a contact problem that might be the cause.
And I almost forgot....I have uninstalled and reinstalled VisTitle.
In any case, it's only the VisTitle dongle that exhibits the random drop outs. The others are all rock solid. I've been living with the VisTitle dongle problem for a couple of months now, but it's starting to drive me crazy, plus I've got a job to update some video that uses VisTitle extensively (sometimes I use VisTitle as an "After Effects Lite").
George Dame suggested I check the USB managment, etc. I've done this, and see nothing unusual. I'm convinced it's a defective dongle (I see from the forums that others have come to the same conclusion).
Any suggestions? Thanks.
