Hi, I'm using Edius 6 and I know NewBlue Essential II has a noise reducer program but I don't know if I can use it with Edius 6. Is there a plugins for Edius 6.
CPU: Intel i9 7940X
SSD Drive:
Ulisse
Yes it works in E6 and does a good job BUT is definitely not RT rather snail time
Make sure you have the latest update from Newblue or you could be in trouble
Takes a super long time to render too
It can cause you problems if Edius looses the render, so I always use shift+Q to render to a new file and then delete the original from the timeline
