Hi ...
Hope someone can suggest fix. My TMPro credit roll is flickering.....a problem I've had before........but nothing I've done so far stops the flicker. It looks great in Edius...but flickers on the DVD.
I tried using the smooth roll tips from Anton.....but still the roll flickers.
It's 3 pages....arial font....so used the x2 243 8:03 Anton formula.
So I made the roll 24 seconds plus 9 frames. Still flickers. (Or should that be 24 seconds 4 frames?) Then I tried some random lengths...a real hassle because I'm burning through DVDs to check the roll.
Any suggestions?
Sheeba
Sheeba
Any suggestions?
Sheeba
Sheeba
