This totally depends on your needs. Anton's suggestions is a good one but not much use if you don't do much keying.
For pure effects mine would be Sapphire or Looks 2 but neither fit into a tight budget.
What do you want, filters and transitions or other types of effects? If you do key, Robuskey is a must. I can't state that enough.
If you have Edius 6 you can download 3 plugins for free. Vitascene, New Blue Effects, and Mercali. These should hold you over until you decide what other effects you need. You can also go to http://www.edius.jp/download/effect01.html and download all of these filters that can be imported into Edius very easily. If you use Titlemotion Pro, there are a few downloads for that as well.
Video editing programs and video software from proDAD are the perfect solution for creative video projects. Optimize and stabilize your videos perfectly!
How much better is the Pro version from the included version? Do you find it has a lot of useful additions or just more stuff?
Asus Prime X299-A-Intel i9 7900x all cores @4.3GHz 2 cores @4.5GHz - 32GB RAM - NVidia GTX1070 - Edius 9 WG - BM Intensity 4k - Boris RED - Vitascene 2 - Windows 10
