Vistitle - border thickness
  • Vistitle - border thickness
    anyone figure out how to shrink the border thickness of buttons as the button size is reduced
    i could not find any settings
    Scale it in effects mode.
    That's what I do and then I save it as an animation. :)
    There must be a better way but I have not figured it out yet.
      ahhh, that does it
        hmmm, I can scale it down in effects mode and it shows small on external monitor and inside vistitle, then when I save and exit, it returns to its normal size
        the only way to keep the smaller size is by saving as animation rather than as a still
        this however prevents me from stretching the duration when on timeline, so I need to set duration inside the titler each time
          Save it as an annimation then you can set any duration you want.
          You know how to quicly extend the duration right?
          In case you forgot.
          Move mouse to new duration.
          open vistitle (then editor window opens ) click on the duration .
          It will update and you can then stretch it.
          Or make it longer then you think you need the you can stretch any duration between beginning and end.
            yes, I know, I suppose i can live with it
              The vistitle guys must know now the secret. :)
                Sorry, there is no good ways to do your wanted. I think maybe we should develope a functions to do this job -- scale object's shader parameters (outline width, shadow size, etc.. )
                  Sounds great! ;)
                  Andreas Gumm
                  post production / authoring
                  Windows 7 Ultimate,
                  GV hardware: 3G Storm
                  PC 2
                  GV hardware: HD SPARK
                    Originally posted by Andreas_Gumm View Post
                    Sounds great! ;)
                    yes, sounds great to me as well
