Vistitle 1.6
  • Vistitle 1.6
    Vistitle 1.6 update has arrived:
    http://www.vistitle.com/ListDownLoad.asp?ID=25
    The full installer is here:
    http://www.vistitle.com/ListDownLoad.asp?ID=28
    With 20 new features including 3 new plug-ins.
    They seem to be using a better downloader, quicker than the last (for me anyway).
    Very glad to see this happen. I have been waiting for the new features for quite a while.
    Thanks for the tip off
      I read the additions and fixes and I have to tell you, these guys do listen.
      It looks as if a significant portion of the 'user requests' have been addressed with a few of these additions.
        I only see the 1.6 update. Will there be a full installer, too?
          GUI problems after updating with VisTitle 1.6!
          After VisTitle has been updated I get some problems in the GUI.
          If I click on any of the main items in the menu bar in main edit window no menu pulls down.
          The icon bar in next line will not change in context of the selected main menu item!
          I used a german localized languag file in version 1.5.4 before updating,
          the NVIDIA patch has been applied!
          OS = Windows XP SP3
          Can anyone confirm the issue?
          Andreas Gumm
          post production / authoring
          Windows 7 Ultimate,
          GV hardware: 3G Storm
          PC 2
          GV hardware: HD SPARK
            After a complete deinstallation of Vistitle & a complete reinstallation (version 1.5.4 first, then 1.6) it works fine!
            Maybe the language pack caused the issue?
            Andreas Gumm
            Windows 7 Ultimate,
            PC 2
              The full version of VisTitle 1.6 is up now!
              http://vistitle.com/listdownload.asp?id=28
              @John
              maybe you can update your first posting with the additional link?
              Andreas Gumm
              Windows 7 Ultimate,
              PC 2
                OS = Windows XP SP3
                This was happened in some cases, when the dongle was lost. Restart the application will fix this issues.
                  I just had a chance to update to 1.6 and try the shadow plug-in which is something that I had brought up here a few times and Jack ( VX Chen) ackowledged.
                  the shadow pugin is outstanding and the mirror feature is awesome.
                  well done Jack and the rest of the team at Videostar
                  John Sirb
                  Lake Breeze Video Lorain,OH
                  SYS 1: Edius 9, Vistitle 2.5, Boris Red,Neat Video, Gigabyte Z170x G5, I7 6700K 4.0Mz Skylake, G.SKILL Ripjaws X Series 8GB x2, NVIDIA QUARTO 2000
                  JVC HM-100,JVC HM-700, JVC HM-600, Canon 80D
                    I updated to ver. 1.6 and now get "Encountered an improper argument". The program seems to be working but as a new user, I'm not sure if all is okay.
                    Bob
                    Edius 8.1wg, Intel Core i7 Extreme 965 8-Core 3.0GHz, 12G RAM,
                      just as a follow up, one thing is the popup window for shadow is too large so I can see the bottons on the botton and resizing the window does not work
                      John Sirb
                        Bob
                        Do you always get this message box ? Can you uninstall VisTitle and try install the 1.6 full installer to check again ?
                          How to get this ? Can you describe some details step to repeat that?
                            Click on image in layer
                            Go to Plug In Icon and launch Shadow
                            make changes
                            requester comes up when using X
                            John Sirb
                              I did the update not the full install so I'll try the full update.
                              Bob
