tmpgenc5 license validation
  • tmpgenc5 license validation
    Has anyone noticed that tmpgenc5 is checking the license online much more often then tmpgenc 4 did? I have not used version 5 that much but it seems it's connecting online twice as often as version 4 to check validity.
    untick the option to automatically check if license is valid, then it will only happen seldom
      Thx for the tip Anton!
        I just installed Windows 7 Service pack 1. Guess what, afterwards, I had to re populate the serial number, name & email to get a validation.
        User friendly (not)
          I also installed service pack one, but via windows updates and had no issues with T5
          did you download the full SP1 redistributable package?
            No Anton, I used Windows update.
