Vitascene 2.0 trial version does not work in Edius 6.02
  • Vitascene 2.0 trial version does not work in Edius 6.02
    I have downloaded a trialversion of Vitascene 2.0 but it doesn't appear in my Edius 6.02.
    I have tried so many things but it doesn't work, I always get the Vitascene 1.1.89 version and not the demo version.
    Can anyone tell me step by step how to use vitascene 2.0 ?
    Did you download the correct 32 bit version?
      No I used the 64bit version because my pc is a 64 bit system (i think ...)
        EDIUS is 32 bit so you would need the 32 bit version regardless of OS.
          OK thanks, I will try this.
            I have tried this but nothing.
            Then a mail to prodad.
            Answer :
            Hello, please make the following now :
            - Deinstall Vitascene
            - Clean your Registry (regedit), delete all Vitascene entries.
            - delete Vitascene folder (c:\Programme\proDAD....
            - Deactivate the User Access Control – reboot your system as admin
            - New installation of the Vitascene 2.0 beta
            - Activate the User Access Control – reboot
            I have done all these steps but no Vitascene.
            I also have installed a plugin for Magix and there it works...
            Help !!!!!!!
              And now I have installed vitascene version 1 from the bonus software cd and that one is also not working.
              I need an effect for a project next week, so i'm a little in panic ...
                You are a bot confusing at this point.
                What happens do you see the plug-in in the effects list and it is not working when you apply it or you don't see it in the effects list?
                Please clarify . Thanks
                  Oh sorry, I can't see it in the effects plug in...
                    That's better.
                    Do the following start EDIUS.
                    Go to the effects Pallet
                    Right click in the gray area
                    Select return to default.
                    Now check if you can see the plugin.
                      OK I went into the gray area - set to default - but still no vitascene
                      Did I mention that in Magix VDL the plugin works ?
                        I think you did something wrong.
                        Set as default is for transition
                        What you should do is
                        Return to Default which will cycle the list and close the folder.
                        EDIUS has nothing to do with Magix so no need to bring it up
                          Sorry,
                          Didn't mean anything, just wanted to give extra info.
                          Don't understand :
                          i went to effect
                          r click
                          message : return to default
                          Ok
                          Settings set to default
                          That's what i did, but still no vitascene, well mercali
                            Ok can you go to the EDIUS folder-> plugins and make a screenshot and post it?
                              I replied via the mail and send a screenshot
