Downscaling Vistitle rolls/scrolls with TMPGenc5
  • Downscaling Vistitle rolls/scrolls with TMPGenc5
    When I downscale an HD show with TMPG5 with Vistitle rolls and crawls in it, I get a stairstepping motion-not smooth. I am downscaling only the video and adding the crawls and rolls on an SD timeline. Is there a better workflow out there?
    EDIUS Workgroups 8 with NX Hardware plus HD expansion Card,
    EDITHD Workstation: Intel Core i7 [email protected], Nvidia GTX-950 Video Card, Windows 7 Premium, 64bit, 6GB Ram, Vistitle 2.6.0.6, Robuskey, ChromaKeyer Pro,
    downscale from what to what? 1920 - 480/576 or 1440 - 480/576
    is the source NTSC or Pal
      This was downscaling 1440 to 720X480 mov (NTSC)
        sorry, never tried mov
        works alright to downscale to avi or DVD mpeg spec
          I guess what I'm seeing is just the difference between HS and SD on the roll. The SD version rolls smooth, but it's like you can see lines flickering thru it. The HD is beautiful. It may be my monitor. I just downconverted again and it still looks slightly better applying the roll on a SD timeline and exporting verses having the roll on an HD timeline and downconverting the whole thing.
            I know the rolls that I have done with Vistitle are clean. My SD file comes from an HD master that has been washed through Virtual Dub and then encoded out to mpeg2 mastering settings in Procoder 3.
              Thanks, I will try the antiflickering fliter. And bolder should help.
