What's Best output setting for bluray using TMPG 5
  • What's Best output setting for bluray using TMPG 5
    Can anyone pls advice the best output setting for bluray using tmpg5
    am going to be using adobe encore for authoring.
    thanks.
    Window7, 64bit,Edius6.03,5.51,HDStorm, VisTitle,AMD Phenom11X4 Quadcore Asus CrossHair Motherboard,8Gigs of Ram,1TbCdrives,3Tb Videodrives SoundBlasterX-fi
    http://vimeo.com/channels/sunflow
    www.sunflows.com
    http://www.sunflowphoto.com/
    Did you try this from Anton.
    http://www.videoproductions.com.au/html/t5-hd-sd.html
    Tony
      Thanks Tony, but that setting is for HD to SD
      www.sunflows.com
        thanks.
        it depends on your source, is it Pal or NTSC or 1920/1440/1270, interlaced or progressive?
        if 1920x1080 Pal interlaced, you can try my template at the bottom of this page
