Trying to download AE CS5, but have a 32 bit system???
  • Trying to download AE CS5, but have a 32 bit system???
    Hi folks,
    I hope I'm in the right place to ask this question? - anyway:
    I'm running Edius on my Windows XP (Media Center Edition) and ordered After Affects. When I tried to download the AE software which arrived today, I got a message saying my computer needed to be 64 bit, and it would not work on my 32 bit system. Forgive me, as I'm "technically challenged"! Can you please advise me as to what I should do and how to do it. BTW, my computer is a:
    Dell XPS 720, with Intel Quad CPU
    Q6600 @2.40 GHZ
    2.50 GB of Ram
    Sorry, all greek to me! Any advice would be so much appreciated.
    Mark
    Mark
    You need either Vista 64 or Win 7 64 operating system to run it, XP64 not recommended by many users here
      So all I need to do it go to the likes of Best Buy and buy Window Vista and then it will work?
      Mark
      Mark
        I just installed the full CS5 Production Premium suite, 64bit Premiere, Photoshop, Encore, After effects, ect ect, and put in a Blackmagic card, Premiere Pro 64bit runs very well now with a high end system and heaps of memory, oh yeah and a Quadro FX4800 GPU, very happy so far..
          Also be advised that your computer is a bit on the weak side and you may have trouble running some things.
            Mark
            First you should start by looking if all the applications you use on your xp system work with Windows 7 or have updates/upgrades to make them compatible.
            You should also run the windows 7 upgrade advisor to check if your system is fit for win 7
            http://windows.microsoft.com/upgradeadvisor
              When I remember correctly, my copy of Production Suite Premium CS5 shipped with the 32Bit versions of Premiere CS4 and AEffects CS4.
                Thanks for that link Steve, I'll check it out!
                Mark
                Mark
