Virtual Dub 64-bit
  • Virtual Dub 64-bit
    Anyone having success using the 64-bit verison of Virtual Dub with Edius captured files?
    Which codecs work for you?
    Edius has no 64bit codec so you need to use the 32bit version
      I was afraid you would say that. But thanks.
        but works with uncompressed RGB - no? I mean for convertion after edit, obviously not from captured stuff....
