Vistitle 1.5.3 not compatible to 1.5.2?
  • Vistitle 1.5.3 not compatible to 1.5.2?
    Hi Jack,
    after updating to 1.5.3: opening an EDIUS 6 project using titles made on v.1.5.2 ---> all title clips are "offline".
    Is 1.5.3 incompatible to v1.5.2?
    German localize doesn't work on 1.53 either!
    Eric
    English is not my native language
    ___________________________________
    System 1:Intel core i7-6700K 4 GHz - ASUS Z170-A - 32 GB DDR4 RAM - Intel HD 530 Graphic - Win 10 Pro - Storm 3G - Blu-Ray LG BH10LS30
    System 2: Intel i7-960 3,2 GHz - ASUS P6T - 12 GB DDR3 RAM - Radeon HD 5850 1GB - Win7 Ult 64bit SP1 - Storm 3G - Blu-Ray LG BH08LS20 - LG GH22NS50
    Originally posted by Eric
    Hi Jack,
    Eric
    Localize (1.5.2) is not work with 1.53, we had update them to dealer, please contact with them.
    But, the layout file (1.5.2) should be compatible. It can be used in newer version. For test this, please import your layout files(1.5.2) to 1.5.3, it should be OK.
    If you open the EDIUS project, and the title was "offline", please check the title layout file path is OK.
      Jack, the layout files are not working on 1.5.3 :(
      1. I've checked PATH: is OK
      2. I can import the 1.5.2 title layout, but it is still marked as "offline" on BIN window.
      It's very strange, I can handle the files, but the are shown as offline.
      Eric
        Earlier titles work fine here.
          Eric
          Please try this to test:
          1) New a EDIUS project
          2) Import your 1.5.2 layout files to EDIUS bin window
          Is it all right?
            If I rename the file, I can not import it --> error code "can't open file"
            original file can be imported, but shown as offline.
            Creating a new EDIUS project --> same problem, can't open/import the file
            Eric
              looks like a localize issue? because it works fine here with English OS
                Eric
                Do you have applied German Localized PID files to system ?
                Because German Localized PID files (1.5.2 version) is not work in VisTitle 1.5.3, so if it is still there, VisTitle cannot work well.
                Please to sure whether you can run VisTitle 1.5.3 with standalone mode ? And, if yes, can you import 1.5.2 layout to VisTitle 1.5.3 main program ?
                  Yes, there is a german localize.pid installed.
                  There was no information, that localize doesn't fit to 1.5.3.
                  I made a new installation and it works fine.
                  I'm waiting for the new LOCALIZE.pid
                  Thanks a lot
                  Eric
                    Thanks a lot
                    Eric
                    Ok, please contact your German Dealer to get the 1.5.3 German localized PID files.
                      Hello Jack,
                      I have testet the latest "VexelTitle.pid" and everything works fine now on VT 1.5.3. / german language
                      Eric
