View Post
Dvd it Pro HD 6.4
But in DVD tmpenc will encod hd to sd?
Will it be good quality and not too long?PC PRINCIPAL: intensificateur 4k pro - edius X- maximus heroX wifi - processeur Intel I7 8700K; mémoire 16 Go SKILL - xpredator2 - corsair 650W HX
maybe I download the latest and have another play to see what they improved
wow wow and wow, testing now
there have been many improvements, it leaves DVDit for dead 3x overAnton Strauss
Have to try the two-window, copy and paste tip from above. Thanks.
My main issue is startign with AW4 was to realize that unlike the other authoring program I've used (e.g., ReelDVD, Encore, DLP) where you build the DVD structure and menus by adding "stuff", with AW4 it seems to me it started with a full plate DVD structure, and I had to remove the stuff I do not want. Once past that realization (at least to my thinking, such as it is) it was easy.
Originally posted by dpalomaki View PostHave to try the two-window, copy and paste tip from above. Thanks.
We have to think first the number of button we wantPC PRINCIPAL: intensificateur 4k pro - edius X- maximus heroX wifi - processeur Intel I7 8700K; mémoire 16 Go SKILL - xpredator2 - corsair 650W HX
Originally posted by iibw View PostI found a thread explaining a shortcut. Open two windows, one in HD and the other in standard def, then cut and paste the timeline from one to the other. All modifications, chapters, etc gets transferred intact. Although not perfect, at least it's a step in the right direction.
Agree
Anybody out there tried it before? What is the quallity like? What are the Edius MPEG-2 settings to use in order for TNPGEnc not to reencode?
ThanksBigRick, Montreal, Canada
EDIUS 8.3 with HDSpark - Intel I7-3770k, 16 GB Ram, Windows 10 64bit Home Premium, ASUS GF GTX560 TI 1 Gb Video Card and Intel® HD Graphics 4000, 2 X LCD 24" Monitors (1920X1200), 1 X LCD 32" Television
1 SSD Samsung 500 Gb (System),1 SSD Samsung 500 Gb (Video data), 2 X 3TB Sata II, and others
authoring works accepts Edius elementary streams, providing authoring works is set to Automatic/Smart Rendering Prioritized
http://www.videoproductions.com.au/h...ay-export.html (very fast export, uses all cores at 100%)
TAW4 menu render quality is excellent, smooth text and highlights, leaves Edius menu quality for dead, which looks like everything was attached by mice
and be sure to click and right click anything you see, you will find that TAW4 has advanced settings on every item making it in a way much more powerful than DVDit Pro HDAnton Strauss
Does TAW4 have CSS and DLT tape output for SD?
TIA
JohnnyDEdius7, 4790K, 16G, Win7, GTX970ti MatroxLE
Atari 400
JohnFellersProd
CSS is enabled at the replication plant during glass master creation, so you don't need that as part of authoring
there is no DLT output, you don't need that, use DVD-R, no problems with replicators, they do a quality check before creating the glass master
I never used a DLT in 10 years nowAnton Strauss
Originally posted by antonsvideo View Postauthoring works accepts Edius elementary streams, providing authoring works is set to Automatic/Smart Rendering Prioritized
I noticed this post and wanted to ask a question. I just downloaded the Authoring Works trial and have imported an encoded 720p60 Mpeg-2 .m2v and its audio file into Authoring Works and it wants to re-encode the file.
The m2v file is 20GB yet AW disc output size is 10GB. I have the setting set as you show. Any other settings? Encore shows "don't transcode"...
ThanksAsus PrimeZ690A - Intel i9 13900K - 32GB RAM - NVidia GTX1070 - Edius X WG - BM Intensity 4k - Boris RED - Vitascene 2 - Windows 11
I personnally don't see any benefit to using elementary streams. You surely have a reason for using them. What am I missing?
Also have another question: you suggested the following TMPGEnc settings:- Encoder Mode: Automatic
- Max Bitrate: 24000
- Bitrate: 24000
- Min. bitrate: 5830
- Picture quality: 90%
Can you explain the 90% picture quality as opposed to 100% and what about the bitrates, they are set to lower than the Edius average output of 25000 and max of 35000 ?
Am I missing something again?
Regards....Last edited by bigrick; 01-21-2011, 06:20 PM.BigRick, Montreal, Canada
Originally posted by pjsssss View PostMost authoring programs require elementary streams.
A lot of authoring apps can take pre-muxed files such as mpeg and m2ts. But like Pat said they do prefere elementary streams, as they like to do their own muxing. Depending on what you do to the streams in the authoring app, like adding audio, subtitles, angles etc. The authoring app would only have to demuxed any transport or muxed streams anyway in order to remux with the extra info.
Cheers.
Dave.
yes, in order to create a DVD or Blu-ray, muxing needs to take place
in order to mux, elementary streams are required
so if you geed the program a program stream, it will accept, it will demux it and then remux it and it will take longer
make your choice
example: to make a DVD, VOB files get created, they are a mux of video, one or more audio streams, one or more subtitle streamsAnton Strauss
