Heroglyph plugin
  • Heroglyph plugin
    Hi guys..I have Heroglyph installed with Edius 6, and it is working ok, but whenever I close Edius, I am now getting a message suggesting that edius was not closed, and I have to tell it to close.....It also changes the colour scheme......has anyone had these issues?....and what can i do to solve them
    Hi,
    I have the same problem with all ProDAD plugins. For me it's annoying but fortunately harmless since my projects get not corrupt.
    Best, Gregor
    Gregor Haberhauer
      I solved the colour scheme issue, by changing to Windows 7 Basic, rather than Windows7 Areo...The basic also has the system running faster as well
        You wrote: Heroglyph...is working ok... Really? Do you see the background video? If so please tell me your settings.
        Albatros
          OK Set in Background:
          Black, and tick all three options, and when finished, do not export, just save, and use < File: select: Back to editing program, or press F12>
          That is all I did
            That is all I did
            That deos not make the background video appear in the heroglyph interface as a background to the title you are composing. It just takes the title back to the Edius timeline.
            I have tried everything I can think of to get the Edius video to show in the Heroglyph interface so that I can compose the title in the precise spot on the video where I require it. All of the other title programs will do this. Does any one have instructions on how to do this?
              When you go into <Settings>, select background, and tick the 'Transparent', and 'show background'....that is what I did, and mine is working perfect....when I am finished, all I do is save, and hit F12, and that is all.......
