Is there a new version of Adorage for Edius 6? I dont see it anywhere on Prodads site. Same for the other programs I know some come with Edius 6 but not all the ones I use. ie Heroglyph & Adorage.
Edius 6 plug ins
7 What will be bundled with EDIUS 6?
Bundled Software:
NewBlue video filters: Video Essentials for EDIUS
ProDAD video effects & image stabilization: VitaScene & Mercalli V2
iZotope VST audio plug-ins: Audio Effects Suite, AudioRestore, AGC, and Mastering Effects Suite
These are plugins for Edius 6.Jerry
Main System:: Azrock z690 Taichi, [email protected], 64gb ram, Lian Li Galahad 360mm in push pull, Lian Li 011 Dynamic XL ROG case, 13 Lian Infinity fans, Win11 Pro , Samsung 980 1tb boot NVME, 2TB Sabrent M.2 NVME, 2 TB WD 850x NVME, 1TB Samsung SSD, 12TB Raid 0, BM MINI MONITOR 4K, , Dual LG 27GK65S-B 144Hz monitors, GTX 1080ti SC Black Edius X.
Second System: EditHD Ultimax-i7, X58, [email protected], Corsair H80, Win764, 24gb ram, Storm 3g, Samsung 840 Pro 256, 4tb and 6tb RAID 0 on backplane, GTX 980ti Classified, Edius 9.55, Apple 30", Samsung 24", dual BD. -
yes those are the ones that come with Edius 6 I mean the ones I bought for Edius that are not part of the bundle. Like Adorage 10 which I use A LOT. Prodads site says its compatible but doesnt have a new version to download.Randy
Asus sabertooth MB Z97 16 gigs of ram SSD system and edit drives Nvidia GTX-660 video cardComment
Just wanted to thank everyone for bringing this to our attention. We are now researching the issue and will let you know when the resolution is available.Comment
solution?
hello
Does anyone know if there's already a solution available for this problem?
I use these Adorage effects a lot!
thanks!Comment
Please contact Prodad. Adorage is not a GV product.Comment
We have been working hard to resolve all issues found in the Edius 6 bundle. For everyone experiencing issues with the bundled version, please try this version:
Thank you for your patience with this. We will certainly always work to resolve any issues found with our products.Comment
Hey Rando, keep an eye out for Adorage 12 from proDAD, which should be shipping in December. In addition to some new effects, it also contains updated plug-ins that will make it and previous Adorage volumes compatible with Edius 6. You also mentioned VitaScene; a new version of VitaScene is coming too which will have some cool new features, better rendering, and yes...work with Edius 6. There will be some attractive promotions too I'm sure.Comment
I want XPLODE PRO Support For EDIUS 6
Hi Everyone i think EDIUS has changed the plugin structure
That's why i cannot install XplodePro in edius 6.0
It is very important for my Business
Can Anyone has any solution for thisAVCS SYSTEMS INDIA www.avcsindia.com, Email : [email protected]Comment
Sorry, it will not be supported, and we will not support hacks or modifications to make it work, because those things can break the system.
If Xplode is necessary for your business, stay with the EDIUS version it works in.Comment
to GPU effects in Edius 5. You should be able to find most of the Xplode
effects in that bunch....and all RT that work with alpha(in Edius 6).Jerry
Second System: EditHD Ultimax-i7, X58, [email protected], Corsair H80, Win764, 24gb ram, Storm 3g, Samsung 840 Pro 256, 4tb and 6tb RAID 0 on backplane, GTX 980ti Classified, Edius 9.55, Apple 30", Samsung 24", dual BD.Comment
I kindly ask not to post the same question in different threads.
As stated before support for xplode pro stopped with the introduction of EDIUS 5.
Xplode pro will not work in EDIUS 6.Last edited by GrassValley_SL; 12-08-2010, 03:27 AM.Comment
GIVE Me any alternate of importing 3d files in edius
I know that xplode is not supported in edius but is there any alternate
software that supports edius.
or if you can make xplode compatible for my business
i would be very greatfulAVCS SYSTEMS INDIA www.avcsindia.com, Email : [email protected]Comment
Although everyone knows that the Xplode Pro is not officially supported from EDIUS 5, nor will it ever... but there are always people who create new codes that would divert the installer and enable the plug-in works such as in EDIUS 5, and maybe one of them also do EDIUS 6... although this is not officially recognized.CSXD2 l For EDIUS Pro 6.5
http://cinemasuite.blogspot.com/Comment
