Vistitle
  • Vistitle
    Hi all,
    I plan to buy a Videotitle, but I don't know between Title motion pro and Vistitle is the best, and where can I get those?
    Thank you
    There are no universals in life.
    You need to explain a little more what kind of titling you do, or want to do. Then people should be able to give you better advice applicable to your use.
      vistitle
      Hi all,
      Especially for video wedding, and they are compactible with a chinese font.
      Thank You
        I think Vistitle is MUCH better than TMP.
          I have TMP and Vistitle. The learning curve for Vistitle may be a little steeper than TMP, but will yield much cleaner results.
            Vistitle>>>>>>My choice.
            Mule
            EDIUS v5.51 Broadcast - Dual Xeon Supermicro X7DWA-N with E5450 3.0GHz CPU (8 cores)
            4 GB Ram, 1.0 TB Video Raid (2x500). 5 ea 1.0 TB External Video. 2 500 gb Ext, 320 GB OS Drive .. ATI Radeon HD 4350 with 512 Ram XP Pro with SP 3 HD Sparks, VisTitle
            Edius 6.52Dual Xeon Asus P5E3 9650 3.0 4G Ram
            Nvidia9800, 500G Raid (2x250) 1TB&500TB Ext Drives
            HPX 2000 AVC Intra, HVX 200, HPX 170, AG-AF 100, Canon D5 MKll.....MacBook G4 w/VMWare FCP Edius 6.2
              I have both, but if I had to purchase only one it would be VT
              Alan
              Alan.
