denoise Plugin
  • denoise Plugin
    hi all ...
    I have to remove noise in my video..
    İs there a any denoise plugin for edius ...or anyway to remove noise..
    can someone help me..
    thanx for all..
    Neat Video as a plug-in for Adobe After Effects or Premiere Pro (both CS5 in my case) works very well. No plug-in for Edius.
    i7 3930K, Win 10 pro 64 Bit.
    RAM 32 GB.
    ASUS P9X79-Deluxe.
    PS Thermaltake 1kW.
    Graphics Gigabyte GTX1660 OC.
      You can remove some mild video noise in Edius. The Median filter is one method, using Motion Blur and Sharpening is another.
        There is a plug-in package from New Blue-Noise Reduser. Works fine in Edius
        Windows 10 x64, Edius 6.55, Edius 8 Pro, Intel 4790K, ASUS Z87-PLUS , DDR 32 Gb, Nvidia GeForce 780 , Apple Cinema Display 27, Canopus NX with Expansion kit
          I have found that using the Temporal Smoother filter in Virtual Dub can make a big improvement to second generation VHS recordings. Overall the results are impressive but certain types of transitions can end up looking worse.
