My first 5.51 problem is as follows:
1) I place several individual clips on the time line
2) I then add 3d p in p effect. So far so good.
3) When I add a default transition the cut points disappear on the white/grey track and all the clips take on the same effect ie. individually set 3D p in p. Why? I end up by having to use the "old fashioned way" and put individual clips on different tracks.
My second is: how do I get four pictures with white lines or soft edges on the same frame/line at the same time?
Kind regards
Chris Abram
Kind regards
Chris Abram
